Hi, the sister in law owns a 02 Cooper with CVT Auto. Has developed a large problem and thought maybe someone on here could maybe help us out.
Symptoms -
When slowing down from about 20kph and less it shudders real bad.
To a point where when you stop, the idle doesn't recover and it stalls.
Problem has been getting worse over the past couple weeks.
Happens more when the motor is cold and less when the motor is warm.
Not sure if its the brakes or the CVT or the ECU or engine or whatever
If you need any more info let me know.
Claeten
- '74 Clubman Ute project
