It is currently Mon Jun 23, 2025 10:24 pm
Post new topic Reply to topic  [ 281 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 19  Next
PostPosted: Mon Apr 01, 2013 6:46 pm
that engine looks the business, amazing how tall they look when out of the car
PostPosted: Tue Apr 09, 2013 9:44 am
Thats strange with the cams getting mixed up, Im sure in my 8v head they only fit in the one way. i.e. impossible to mix up. Is the 16v head different?
PostPosted: Wed Apr 10, 2013 3:18 pm
yeah you cant mix up the 8v cams,,, they`re caps are such that it`s imposible to fit them wrong
the 16v caps are the same set-up inlet & exhaust so it`s an easy mistake for the un-initiated
when Steve rang me about it i told him that i`d almost bet that`s whats happened with his head :-)
PostPosted: Fri Apr 26, 2013 9:35 am
Still creeping along, there was a fair bit of angst setting up the cam timing and getting the require valve to piston clearance. So after a call to MattR I set it up as suggested 2.5mm lift, "On the Rock"
If you are like me and don't know what that means, here's a non-technical version. When the #1 cyclinder is at Top Dead Centre on the firing stroke the inlet & exhaust values at #4 are open 2.5mm.
In the pic above it was just before the 2.5mm lift.
At that I had valve to piston clearance, but not a lot, so at that point I opted for a thicker head gasket and had a 2mm gasket made. This has given me better clearance and got the CR at just on 11.0:1
Then started to bolt it together.
Now for the fuel and spark, which will be a Mircotech set up.
Dalmeny
PostPosted: Fri Apr 26, 2013 1:55 pm
Looking very very close......so close i could picture it strapped down with a big fan in front of it.
will it pop in with the exhaust manifold hanging?
PostPosted: Fri Apr 26, 2013 3:20 pm
Very nice! Image
PostPosted: Fri Apr 26, 2013 7:01 pm
can't wait to see this in the car, gonna look absolutely brilliant
PostPosted: Fri Apr 26, 2013 9:55 pm
What's your plan for an alternator and oil filter/pipes?
PostPosted: Fri Apr 26, 2013 10:09 pm
I hope so, if not I'll come up with the subby!!
Dalmeny
PostPosted: Fri Apr 26, 2013 10:14 pm
I was going to use the reco one off the 1098. The oil filter will be a spin on, also off the 1098. I was going to get a MED billet one with the braided hose, but it won't work any better than the on off the 1098, so I thought the money could be better spent elsewhere.
Dalmeny
PostPosted: Wed May 01, 2013 10:43 am
Its looking great mate!
The bmw head on an A-series looks like it was meant to be. So natural.
Its a nice exhaust too. Is it custom or off the shelf?
1963 850 - laid up
PostPosted: Wed May 01, 2013 5:40 pm
The exhaust is one of Matt Reids....so off the shelf.
PostPosted: Thu May 02, 2013 8:56 am
It looks very well made (not that i dont expect it from matt), i like the angles and sweeps. Its another quality addition to the car
1963 850 - laid up
PostPosted: Fri May 24, 2013 9:15 am
Well, it's been 12months to the day since I purchased the 1100s bock and crank. The last couple of months has involved waiting for other people to do their thing for the build.
I'm now off the road, the 1098 engine is out, reluctantly, it's been going so well and has got better with each additional mile. With still just 3k miles on the rebuild.
Getting ready to lift the ''Twinky'' in. Just need a little more alloy welding on the radiator for the by-pass and heater returns. Then wiring up the Microtech ECU and plumbing the fuel system.
Sneek peek so far.
Dalmeny
 Post subject: twinky sexcy!!!
PostPosted: Fri May 24, 2013 11:10 am
that is one fantastic motor
congratulations on a top looking engine
im in my first stages of a worked 1100 just about to drop that into my mini
but big head 1300 looks the good seriously contemplating this build.
did you purchase a dvd from matt?
ps
your gt clubby on minis in the gong junes picture
i flipped it over early... :lol:
Fried Ricer
Users browsing this forum: No registered users and 23 guests
