It is currently Sun Jun 29, 2025 7:23 am
PostPosted: Sun Apr 21, 2013 5:23 pm
I am doing a rod change box for a mate, and pulling it apart I found this. Looks like the main shaft has been machined down and a new bit machined up.
It's a neat fit, but does turn and looks like it's been fretting a bit, and not as hard as the original shaft.
It measures 13.88mm (meant to be 14mm, right?)
is this normal practice if a shaft is damaged?
should I be concerned?
PostPosted: Sun Apr 21, 2013 5:40 pm
yeah 18mm is the A+ size
so it could be to mix-n-match or maybe just to repair a worn out set
either way i don`t like it spinning & if it`s not "HARD" then it`s rubbish :-)
PostPosted: Sun Apr 21, 2013 6:35 pm
sorry, OD is 13.8mm, ID is something like 10.5mm, it's a normal A series input shaft
PostPosted: Sun Apr 21, 2013 7:10 pm
ah , my mistake,,, where`s my glasses???
Yeah ok it`s got to have just been an attempt to repair then
seen em plenty times before, some good , some not so good :-)
PostPosted: Wed Apr 24, 2013 5:23 pm
oops, sorry Matt, forgot to reply - thanks muchly
There is a stamping on the casing from a mini specialist I trust, so I think it might be one of the 'good' ones - will stick with it
I measured a standard shaft and it is the same size
PostPosted: Wed Apr 24, 2013 9:38 pm
I reckon i can see a lip on the sleeve in the first pic. But that is just from where i'm sitting.
PostPosted: Wed Apr 24, 2013 9:44 pm
Someone has sleeved it as I do for repair, but they have NOT used a bearing inner ring. These are hardened RC62 or better for running rollers on. The ones I use are p/no IRT 1020-2.
These rings are 14mm OD and 10mm ID x 20mm long. They are a bit long but I grind the end back flush, once fitted.
PostPosted: Wed Apr 24, 2013 10:01 pm
interesting - I'll ring my bearing man
mini_mad_matt wrote:
lip
there is a lip there...
PostPosted: Wed Apr 24, 2013 10:07 pm
Give them .0005" (1/2 a thou) interference fit. I warm them a little with the hot air gun, then push them on with the tailstock. A drop of oil on the shaft helps.
PostPosted: Wed Apr 24, 2013 10:42 pm
The fact that i can see a lip and drmini says it's 14mm, not 13.8 tells me it's stuffed :shock:
So i guess the shaft you checked the measurement against is stuffed as well :lol:
This is of course presuming you are adhering to correct measuring practices :P
PostPosted: Wed Apr 24, 2013 11:31 pm
it might have been 13.9, but yeah... there's some wear there
I didn't want to strip the mainshaft! the synchros are all good, it was just a clean out and replace the big bearings :(
grrr :roll:
PostPosted: Wed Apr 24, 2013 11:36 pm
thanks Kev
