It is currently Sun Jun 22, 2025 9:25 pm
Post new topic Reply to topic  [ 236 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 16  Next
PostPosted: Thu Apr 18, 2013 8:26 pm
Die Die Die!!
ok so went and took some pics of the damage today..
and its not too bad however it will need some repair,
plus the PO who did the floor repairs got lazy, they have welded thefloor the the outer wall and the inner had 1inch gap filled with silicone :/
PostPosted: Thu Apr 18, 2013 8:32 pm
But, salvagable!!
PostPosted: Thu Apr 18, 2013 8:36 pm
Its a rough old ride, good thing about the mokes is with everything flat it should be a straight forward process to get it all sorted, plus you can strengthen the areas near the subframe mounts whilst you're at it.
PostPosted: Thu Apr 18, 2013 8:44 pm
Die Die Die!!
im not overly happy with the sand blasting job ( it didnt even remove all the silicone)
but the whole rear of the vehicle is almost imaculate.. just issues around the passenger side bins
battery box
floor pan boxes
and a few other little bits
but the front firewall and most of everything else looks all rust free,
will need 4-5 panels (both sides of the floor (where it meets the wall), battery box, LHS floor box)
PostPosted: Thu Apr 18, 2013 8:56 pm
Silicone is hard to remove with a sandblaster, because its rubbery and the sand just bounces off. What has to be done first is remove most of it with a knife.
It'll come off easy now.
PostPosted: Wed May 22, 2013 6:53 pm
Die Die Die!!
so the rust mob in darwin has quoted me $20k to put the new panels into the moke....
even if buy the panels and supply them.
thats game over for me...
this project has officially hit a stone wall
PostPosted: Wed May 22, 2013 6:58 pm
bog it up , its only a moke
PostPosted: Wed May 22, 2013 7:08 pm
20k ouch, shop around you can buy a lot of hours for that sort of money
Are there any panel beaters on the board who could give you a realistic idea.
Not many shops want to have a job that may take a few weeks
Dont give up
PostPosted: Wed May 22, 2013 7:09 pm
Learn to weld, it's a very handy and fun skill to have under your belt.
PostPosted: Wed May 22, 2013 7:11 pm
Die Die Die!!
Dont give up
the dude who quoted me does a great job, but perhaps its darwin pricing..
i would have thought it would have been alot cheaper if i supply the panels
PostPosted: Wed May 22, 2013 7:17 pm
I've had a car quoted at $20k before for a repair.
It's not necessarily because that's what it'll cost, more the point they're not directly saying - which is that they just aren't interested in the job at all. However, for more than twice what it's worth you'd be silly not to do it.
Personally - I'd just fix it myself - and I cant weld for crap.
Its a moke - the hardest part is making the fill in pieces flat and square.
:D
PostPosted: Wed May 22, 2013 7:19 pm
Die Die Die!!
im seriously considering doing it myself too..
i havnt welded in years however im sure i can pick it up again
PostPosted: Wed May 22, 2013 7:24 pm
Yep time to jump on the welder and do it yourself, there all nice and square once you've put the panels in you could get that guy to doa fill and tidy up if you wanted, but I think a 20K price tag means that they just didn't want to do it.
PostPosted: Wed May 22, 2013 8:16 pm
Darwin pirates!
 Post subject: rust repairs
PostPosted: Wed May 22, 2013 9:29 pm
Do a welding course at ur local tare. only takes a few weeks and u will be able to do the repairs with confidence.
mokes in melb have been selling for up to $29.000 at Shannons.
so don't give-up.
mini regards
peter d
1st victorian road registered vtec mini.
