It is currently Fri Jun 27, 2025 12:53 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Tue Apr 09, 2013 9:43 am
Switch to e85 ethanol for similar results or just run pump fuel
Potato
PostPosted: Tue Apr 09, 2013 12:44 pm
DA9jeff wrote:
I think it's a different colour, too.
Get caught using it on the road in NSW and it's tata to $5K, I think.
I'll stick to my BP or 7/11 premium 98 + Flashlube, works for me.
In SA as well ,plus using it on the race track... Mallala, will incur a fine from the Stewards/Cams.
see last line in my signature below :lol:
DA9jeff wrote:
yeh, Historics only.... see Sec 8.4.6 Schedule G in the Cams Manual
Need Cams authority to use any Leaded fuel as well.
If this is so why do other cars in categories not 5th Category, still run "av gas" (100 octane race fuel) and this is not policed correctly? And with my involvement in motorsport over the years I have never been asked to produce a "Fuel Passport" or questioned when I have bought fuel at the track!
Also if this is coming from the same scrutineers that were going to book group n minis for not having window winders at Easter last year, this is a joke!!!
It seems to be the blind leading the blind in SA!
"Ex" is an unknown quantity and a S"pert" is a drip under pressure!
 Post subject: Re: The right fuel
PostPosted: Tue Apr 09, 2013 3:27 pm
EN40B wrote:
Now that I am building my own race/fast road mini I want to know everything so I do it right
So about fuel - Im assuming that running av gas gives you a slight advantage over PULP? what do you have to do to your engine to be able to safely run it? is it worth it?
so basically.... don't try to set it up to require avgas, which means stay below 11:1 compression (gurus?)
Have it tuned to run best on a particular brand's 98, and always put that in. Don't ever put in 91 or it'll rattle like all hell
PostPosted: Tue Apr 09, 2013 7:15 pm
ah,,,well,,, Simon this can be a can of worms this one
comp ratio & fuel octane rating & that`s not all of it really.
there is the camshaft & the ignition & the size of the engine & a whole pile of factors that will make or not make an engine ping
so,,, a general rule of thumb that i use to describe this problem to the average Joe is that small engines (IE: 850-998-1098) would best be kept under 9.5:1 with std-ish cams
the bigger donks (1275 & up) you can squeeze them to 10:1 with std-ish cams & a little more with a wilder cam, (but just a little)
the big donks (1360 & upwards to 1590) well we`ve seen good results with pump fuel & no pinging on 10.5:1 (with hot road/rally cams & shaped & pollished chambers & attention to detail such as cam timing & ign timing & fueling etc)
alloy heads & crossflow alloy heads & 16v alloy crossflow heads """That we have played with""" (Shaped & pollished chambers etc) we`ve had glory (without pinging) with 11:1 & sometimes 11.5:1,,, but there`s not much room for error up there tho--> say a bad batch of fuel combined with a very hot day :-)
so,,, that`s the best "General" description i can muster at this point :-)
but,,, some will argue against those numbers i1`m sure,,, they`re just general & if anyone does argue with me on this one then i reckon they`re silly in the head ,,,or they`re bullsh!tartists :-)
edit--> Oh & just for the record,,, i`m not talking "WILD FULL RACE" cams here,,, you can build em with more comp ratio with wilder cams like race cars ,,, but i`m just talking about the average road mini engine here
PostPosted: Wed Apr 10, 2013 11:13 am
Matt, interesting that the bigger the motor the more compression you can run. Why is that?
Anything to with a comparatively shorter stroke?
PostPosted: Wed Apr 10, 2013 3:15 pm
more to do with the bore size i believe,,,
V8`s can run way up to 12:1 easilly on pump fuel & yes they have a few more cyls helping keep it rotating too, but they mostly have huge bore size compared to our peeuny little bores (comparatively)
late jap bikes can also run up to around 12 & 13:1 with no dramas on pump fuel & (yet again) they`re way up on bore size compared to us,,,, & of course they have far less weight to lug around, i acknowledge all these helping factors
i`m not too sure on the ducks-guts-intelligence of it all,,,, there are so many governing factors involved--> chamber-fill & swirl-turbulance, squish, flame-front, hot-spots, ignition timing, cam timing, dynamic compression ratio,,, etc etc etc
but i do know what works & what doesn`t in the real world in mini engines on the road :-)
You really do need a little safety margin ... so i always tend to go a tad lower than whats "needed" , just to be on the safe side --> for the sake of a very hot day when someone has bumped the ign a little too advanced & with a poor batch of fuel & up a steep hill in 4th gear etc :-) if you get my drift???,,, i hate pinging, simple as that!!!
if you know what pinging does inside your donk then you`ll be staying well clear of that danger point !!!!!!!!!!!!!!!
comp ratio & cam choice & engine size are all the things to sort when you first start to """design your engine""" & you need to look at it all & """knock""" it all on the head (pun intended :-) ) before you start building the donk ,,, it`s where it all starts... BUT!!! it`s also where it all "may" finish too if it`s not set-up right to suit the fuel you intend to use.
Edit--> I`d bet GR would have some more "hard-core" info/intelligence about this topic than me :-)
