ok,,,to clear this comp ratio thing up a bit,,,it`s easy
make sure when you`re setting up the stroker donk, that you talk with people who have done them for years & years & years
there are some people around saying all sorts of crapo that just confuses the average Joe Blow,,,we have purpose built pistons for exactly this application.
when we build 1415cc stroker """ROAD""" motors, we slice off the top of the piston to make the comp ratio correct for pump road fuel,,,,Now don`t go saying anything about how weak that makes the piston because my dad DESIGNED these pistons to be able to do exactly that!!!!!!!!!!!!!!!!!!!!!!!!!!!!
for race donks we simply leave them the way they are with the big thick strong head on em.
the first ring land is way down the piston so it`s well away from the flame even when the piston top has been lopped off for a roady stroker donk
the very same pistons we use in "NON stroked" 1360cc road & race donks & also leave them as they are
this piston design is now basically , finally being appreciated by others all around the world & some major UK & European piston makers are doing a very similar piston these days,,,FINALLY!!!!!!!
ours are still very good value for money & exceptionally strong,,,you just can`t bust em!!!!!!!!!
It`s all very simple ....-----> In all the cases below, please realize that when """""WE""" build these donks """""WE"""" set the comp ratios to suit the application, but they wil end up pretty close to what`s needed straight out of the box , simply from good design work
so, here`s the list--->
1363cc roady,,,leave the piston how it is,,,just fit it with a std stroke crank & std(ish) cyl head volume
1363cc race donk,,,fit it as it is & use a small chamber head (they`re everywhere these days, just about every race cyl head you see has been decked to the sh!t house so, no problem there)
1415cc road stroker,,,Lop the top off the pistons & select a decent (std-ish) volume road cyl head to suit
1415cc race donk,,,leave piston the way it is (however i do lighten them a fair bit
) & select the very best. big motha cyl head you can get your hands on & set it up at about 13.5:1 or even 14:1 Comp ratio, (Av-Gas only) & then hang on
they are plenty of other types & sizes of stroker able to be built, many many many, different bore sizes, different strokes, different makes /brands of pistons etc etc etc & there are plenty of people around doing all different things in that regard, us included (ala 1510cc & 1600cc & 1430cc & 1450cc & 1470cc etc etc etc), However ,we are very happy to stick with what we KNOW works very well,,,tried & prooven for yonks & yonks, i expect that my dad was "probably" one of the very first in the country to actually stroke a large journal 1275 crank, back in 1969 when the very first Large journal crank came out here,,,my dad (being the Largest Leyland distributor in Qld at the time) had heard about it being produced & imediately thought "HHHhhmmm,,,instant strong stroker mini donk" & grabbed one straight away , they originally used the good old datsun 1200 piston but they were simply not up to the job so he then designed his own piston to suit & hey presto, WICKED STRONG!!!,,, the rest my friends is history, & we`ve done em over & over & over ever since,,,, man i can build em blind folded!!!!!!
anyways,,,keep the thread going, it`s very interesting reading & i also get to understand who actually "Knows" what they`re talking about
