It is currently Mon Jun 23, 2025 8:43 am
Post new topic Reply to topic  [ 281 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 19  Next
PostPosted: Sun Feb 03, 2013 9:32 am
OK! on the CR I intend to have it checked again by the engine tuner, with his equipment and if it's still the same as what I came up with I'll deal with it, as suggested by GR, with the appropriate head gasket thickness. Which should also give me full clearance, maybe :? .
Knowing that the bottom end will stay intact I commenced assembling the the bottom "Twinky" plate and pulleys.
Block ready for the front plate.
Plate attached using countersunk bolts on the Cam Thrust and Crank Cap. This is to clear the rebate in the back of the "Twinky" bottom plate.
Fitted up the pulley seals to the plate. Got the gasket in place losely fitted all the bolts, slide the pulleys in to centre the seals and tightened it up.
Also dry fitted the water pump to check fitment. You will notice 2 countersunk bolts in the pump and one of the webbs on the pump housing removed. This is to clear the timing belt.
The crank pulley is a MED balanced engine management pulley with matching CNC pick up bracket (sensor also comes with it).
And on the otherside a Dutsun 120Y radiator hose is the perfact shape.
Hopefully I can start on the top end sooner rather than latter. :)
ps Matt, any tips on how to tighten the cam nut with levering against the pulley, or do you just do it when the belt is on :?
Dalmeny
PostPosted: Sun Feb 03, 2013 9:39 am
That looks sexual! Awesome job so far
Potato
PostPosted: Sun Feb 03, 2013 9:40 am
Wow that looks good 8) Is the water pump pulley larger than normal?
PostPosted: Sun Feb 03, 2013 10:10 am
Yes it is. It stated in the add that the larger diameter pulley stops or helps the impeller from gravitating (is that the word?). I have no idea if this is fact or fiction, but it looked good :lol:
Dalmeny
PostPosted: Sun Feb 03, 2013 11:16 am
cavitating :-)
& i`m not too sure about it either but what the hell the pulley looks hot hey?
edit--> just to confirm,,, i know what cavitation is & what it does,,, that`s why i corrected Steve with the "Gravitation" thing :-) But what i`m not too sure of is "If" minis suffer from cavitation at hi revs,,, if that was actually so, then i figured that i would have found some problems in that area with our race engines over the last 40 odd years,,, but we havn`t :-) ,,, so,,, i`m not to sure if cavitation is such a problem on minis as some people would try to lead you to believe :-)
& Steve i just grab the pulley real tight in my hand with a rag & a little locktite on the thread & rattle gun it up :-) i have been meaning to make up a tool to fit the pulley teeth nice with a lever off it but just havn`t got there/ havnt bothered
Lookin good Steve
PostPosted: Sun Feb 03, 2013 5:03 pm
TheMiniMan wrote:
cavitating :-)
Lookin good Steve
Ok so what is cavitating?
PostPosted: Sun Feb 03, 2013 5:15 pm
Ahhhh i'l have a shot i used to work on waterpumps on farms/industry etc , cavitation causes the water to eat the metal away inside your pump , from memory its if the pump exceeds the supply of water due to pressure changes in the pipe/system .
PostPosted: Sun Feb 03, 2013 5:18 pm
When an air pocket is formed around the impeller.
The pump churns the water so hard that it creates air bubbles.
PostPosted: Sun Feb 03, 2013 6:47 pm
Both correct, cavitation damages the metal because of the intense energy produced when the vapour bubbles implode.
http://en.m.wikipedia.org/wiki/Cavitation
Pistol shrimp, extreme cavitation used to kill small fish!
http://en.m.wikipedia.org/wiki/Alpheidae#section_3
Edit*
That pulley slows the water pump down so it doesn't cavitate at high revs.
PostPosted: Sun Feb 24, 2013 2:11 pm
So is it running yet :?:
PostPosted: Sun Feb 24, 2013 8:34 pm
I wish!!
Stripped off the gearbox again and back to GR on Saturday to have the appropriate dishes machined into the top of the pistons. Then I will have 11.0:1 with a 40thou head gasket.
Dalmeny
PostPosted: Sat Mar 02, 2013 4:58 pm
BACK ON TRACK!!! :lol:
As stated above, off to GR's this morning for an expert measure up (CC'ing the head and pistons).
As expected I wasn't too far out with my mearsuring. I thought I needed to find another 8cc, which I thought I could get with 3mm H/G, in copper. But, after talking to MattR and Graham, the proper way to do it was dish the pistons.
Graham did some calculations on the first piston, machined it and refitted it for another measure. The total including dish, fly cuts and deck height gave us 10cc's. Head CC 19cc's (a long way from the standard 28cc's hey Matt) and 4cc's for the H/G.
Giving me the desired C/R of 11.4:1
GR machining one of the dishes.
And the difference between the before and after.
And, out of there by lunch time with it assembled. A huge thank you to Graham, whom I'm sure could have been doing something else on a Saturday morning.
Hope those flash new special head gaskets aren't far away :roll:
Dalmeny
PostPosted: Sat Mar 02, 2013 5:38 pm
Looking good.
Can't wait to hear what it will sound like when started for the first time :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Mar 02, 2013 6:16 pm
Will probably sound just like mine....
http://www.youtube.com/watch?v=1Xp9kXKR8Hs
8)
PostPosted: Sat Mar 02, 2013 9:52 pm
8)
Hey smarty, Is that a 16v or 8v and are those the standard cams? It sounds really lumpy. And what air filters are they?
Thanks
Dalmeny
