It is currently Sun Jun 29, 2025 1:56 am
 Post subject: manifold again
PostPosted: Tue May 03, 2005 10:11 pm
whats the best method of removing material from a alloy manifold (redline 3005). i have been using 120 grit wet and dry but it is very slow. i have a die grinder but i'm not to sure it's the best way to go. i am removin material because of extremely lumpy inside. not polishing
PostPosted: Tue May 03, 2005 10:42 pm
Get a carbide burr. Not a straight one, you want it curved so it doesn't dig in.
A bit of RP7 or WD40 inside helps stop it clogging.
I finish it off with 120 grit cloth strip in a slotted 1/4" rod. SLOW it down for this.. :wink:
Those 3005 manifolds really need some metal out to perform well with a 45. You need volume in there. Mine took 9 hours altogether with a carbide burr at 24,000 rpm.. crap I took some metal out.. 8)
PostPosted: Tue May 03, 2005 10:59 pm
thanks. which type do u recomend from this site
http://www.carbidebur.com/18shank/51series.htm
i have a few stone type peices aswell are they any good
PostPosted: Wed May 04, 2005 7:04 am
Can't see the pics, but I use an `oval' and a `tree with pointed end'.
If your grinder has a 1/4" collet, get that size, they stand more abuse.
PostPosted: Wed May 04, 2005 8:53 pm
did u match port it to the block also
PostPosted: Wed May 04, 2005 9:41 pm
I match ported it to a `big port' gasket which matches the head ports.
37mm I think. :shock:
You probably won't go that big, unless it's a race head....
If it's for a 45 carb, it needs a lot taken out of the top flange, most are only about 42mm diameter stock.
PostPosted: Wed May 04, 2005 9:44 pm
I don't get cha... if it's 37mm on the gasket and the flange is 42mm in diameter stock... then why do you need to mod it?? :?
PostPosted: Wed May 04, 2005 9:58 pm
If you don't mod it bigger than the carb (ie 45mm+) there's a step there as the mixture goes in.
Into the head, where it's only about 33mm? dia normally, manifold dia is a little less anyway. Gas speed is higher there than at the carb mounting face.
Anyhow, on these manifolds you don't want a step DOWN where it goes in. Step UP is OK. :wink:
PostPosted: Wed May 04, 2005 11:54 pm
well i have the top half of it out the 45mm now. haven't start at the other end yet because i haven't had time to pull the head off. but i have started to polish the outside of the manifold for extra bling. my mum is doin a good job of it to cause my arm hurts to much. hahaha
PostPosted: Thu May 05, 2005 6:52 am
I'd spend some time on enlarging and smoothing the bit in between, a good indication of how you're going is how much daylight you can see when you look thru it.. :lol:
As I said before, you want some volume in there.
PostPosted: Thu May 05, 2005 8:50 pm
will do. i was out so i missed the snap on truck so it will have to wait 2 week to i get a carbide burr so i can get serious. so i will stick to the stone grinder peices for now
PostPosted: Thu May 05, 2005 8:59 pm
If using stones on alloy, put a bit of wax on them. Beeswax is good, even candlewax helps stop it digging in and loading up.. :wink:
PostPosted: Thu May 05, 2005 9:13 pm
thanks for the tip i will see what i have around the house. do u have any pics of your manifold lookin down the from the carby side
PostPosted: Thu May 05, 2005 9:22 pm
Sorry, no I don't, and it's on the car now.
Here's a pic of my other manifold, (GR one) but the Redline 3005 can only dream of being this open inside..
PostPosted: Thu May 05, 2005 10:39 pm
Thats my Baby 8)
