It is currently Sat Jun 28, 2025 2:27 pm
PostPosted: Tue May 03, 2005 9:06 pm
ok all, its happening again....
LPG.. I'm thinking about it ....
Saw a great tank - about 15" diameter that replaced the spare-wheel well on a Ute..... got me thinking again..
The barrier to LPG on a mini was the tank and the non-sealed rear-firewall....
LPG is 110+ Octane (RON) and although it has a lwoer calorific value, it certainly has the potential to make a shedload of power......
an IMPCO Gas Carb (Think Forklift) is adequate for about 140HP and is very happy in a turbo "Blow-through" application . . . most six-cylinder converters are also more than adequate as well as being cheap as at the wreckers ....
oh, the fuel is also very cheap....
J
PostPosted: Tue May 03, 2005 9:09 pm
According to gas co's current ad in Open Road mag, LPG is 102 (RON). hardly worth it.. except it's cheaper once you've paid all the hardware off. 8)
PostPosted: Tue May 03, 2005 9:12 pm
Bugger.. used to be 111 back when i was buying.... ('92?)
J
PostPosted: Tue May 03, 2005 9:14 pm
Would EFI work rather than using a carb?
A lot of vans run a tank in the back without a firewall.
My work has a 2003 Toyota Hiace SBV with the tank behind the drivers seat.
PostPosted: Tue May 03, 2005 9:17 pm
Dave, but thats up there....
here in the "nanny state" we have to have it behind several shields of spent-uranium .......
Kev, even at 102RON its still better than 90% of petrol fuels.........
J
PostPosted: Tue May 03, 2005 9:26 pm
I was thinkning about this too a while back.
How about instead of LPG use a straight propane tank from a forklift?
The only reason LPG is lower RON now is cos its become a mix between propane and butane(?) and the mixes arent consistant between servos anymore.
Straight propane is about 115-120 RON. The tanks are small too, I dont know if they are different to normal LPG tanks though. I dont see why they should be.
PostPosted: Tue May 03, 2005 10:05 pm
Can't you just run 98 octane with additive?
(Ignore cost, are there any benefits?)
PostPosted: Tue May 03, 2005 10:54 pm
That's what he and I are running now. Great stuff, BP & Mobil's 98, anyhow.
PostPosted: Tue May 03, 2005 11:54 pm
I've always been told that LPG cost less at the pump, but costs more in engine wear...
Stick to a nice 98.
Jonathan
PostPosted: Wed May 04, 2005 12:33 am
LPG is CRAP!!!
We have it in most of our work cars (cheap ass boss) and the have alot less power then the petrol cars :(
PostPosted: Wed May 04, 2005 7:29 am
Lucas, i had a "little" holden V8 running on "that Crap" ....
660@flywheel from a 4.2 litre ...........
When tuned and built for gas, you can get a SHITLOAD more power ......
basically, you can run a LOT more ignition advance and much wilder cam profiles than Petrol.. due to the slower-burn speed of the Gas .....
GRA in Vic have a fantastic Gas-only carb that really makes things sparkle....
J
PostPosted: Wed May 04, 2005 8:42 am
There is an LPG-only Mini in the Vic Mini Club. Watto did a feature on it for Mini Magic several years ago. Uses a gas-research carby and a tank that took up most of the boot. :shock:
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed May 04, 2005 8:58 am
I remember that car, the first mini I ever went in on the road.
Gets around alright, estimated 90hp I think.
I think he's trying to sell it too.
PostPosted: Wed May 04, 2005 9:08 am
James, i have an article of a supercharged LPG mini as well somewhere...i'll try and find it
