It is currently Sun Jun 22, 2025 12:47 pm
Post new topic Reply to topic  [ 236 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 16  Next
PostPosted: Thu Dec 27, 2012 9:43 pm
Die Die Die!!
Haha too true, I have almost everything I need
Did some more before it started raining. Today, took the hood. And hood bows, wind deflectors, rear wheels off today.
Tomorrow the rear subframe. pedal box, and master cylinders will come off
PostPosted: Fri Dec 28, 2012 10:12 pm
Die Die Die!!
so after i removed the rear subframe (there must be a trick to the handbrake cables !) i removed the carpet from the moke, suprisingly rust free..
the worst spot is in the passenger footwell -
PostPosted: Mon Dec 31, 2012 4:05 pm
Die Die Die!!
ok little bit more done today,
front headlights and lenses removed
battery and wiring removed
brake and clutch masters removed
brake lines removed without damaging them so they can be copied
removed the windscreen wiper motor and wipers
removed the bonnet and rubbers
removed all the box covers
not much left to do.. should have the rest out tomorrow ready to take to the sandblasters when i get a chance too,
will also take the seats to the motor trimmers
and the brake lines to the mechanics to get new ones made up
are there any upgrades to the brake lines people suggest while i have the chance ? different guage lines or fittings ?
PostPosted: Mon Dec 31, 2012 9:32 pm
Thats good progress!!!
Standard brake lines are just fine!!
PostPosted: Tue Jan 01, 2013 3:22 pm
Is the floor on the inside flat? (I'm on my phone so I can't see the pictures all that great)
Life's a garden.... Dig It!
PostPosted: Tue Jan 01, 2013 4:29 pm
Die Die Die!!
yeah the floor on the inside is flat as far as i can tell
did some more work on it today, and i tell you what its going to go back together alot easier than it is coming appart, spent quite awhile with the rear towbar..
also removed the dash
windscreen
steering wheel
pedal box
aftermarket alternator bracket
accelrator pedal
numberplate light
i also got most of the way through removing the panel underneath the car for the petrol tank, but i couldnt get one bolt out.. will need to get the grinder onto that one..
all thats left is removing the petrol tank and the rear tail lights on the moke, and to dismantle the rear subframe and then i can take everything to the sandblasters,
i opened up the petrol tank and removed the filter tube and the steel gauze at the end has had it and needs replace and from what i could see there was was a bit of debree inside the tank.. whats the best way for fixing this ? i assume its not rusted through as there was petrol inside still,
while i have the petrol tank out.. what is recomended i do to it ?
Nick
PostPosted: Tue Jan 01, 2013 8:00 pm
Nick,
There is a product you can bu, I cant remember the name of it, but a lot of the classic bike restorers use it to clean out the accumulated gunk in their bike fuel tanks - apparently it works wonders. My brother used it on his Yammie tank which had been sitting for years and cleaned it up just like new!!
I will try and find the name of it for you.
Good work too mate!!
Tricky
PostPosted: Tue Jan 01, 2013 9:53 pm
Die Die Die!!
Muriatic acid ?
or perhaps this stuff - http://www.ppc.au.com/kits3.htm
POR15 tank restore kit
PostPosted: Wed Jan 02, 2013 7:13 am
Die Die Die!!
this is the colour im planning to paint, its called Voodoo Metalic
PostPosted: Wed Jan 02, 2013 8:24 am
_666_ wrote:
Muriatic acid ?
Yes, I think that is what he used (POR15 kit)!!
Nice colour too - some blues are shite, but that is very nice!!
Tricky
PostPosted: Wed Jan 02, 2013 8:35 am
That Is a nice colour I use it on alot of helmets, nice green pearl in it
PostPosted: Wed Jan 02, 2013 8:38 am
Those floors are an earlier quick & dirty replacement. Real floors have ribs in them.
The joint between the front of the floor and the firewall is very important. It is a box section that the end of the subframe attaches to. I have seen too many that have been repaired badly and the box is gone.
I would suggest you check that the car still has the triangular "sills" that are formed by the join between the vertical floor pressing sides and the angled side box sides. These are also important for the structure but are often removed when the rust is repaired.
Since you are doing an engine conversion I assume that originality isn't important for this build. Still, I would think its future value and strucutal integrity would be higher if you tried to get the right repair panels.
M
PostPosted: Wed Jan 02, 2013 12:38 pm
M
Yep, I was getting back to that eventually... Good thing some one got to it
PostPosted: Wed Jan 02, 2013 9:52 pm
Die Die Die!!
ill double check when i get some time off work, however im positive the box sections are still there, as i know one needs to be replaced
PostPosted: Wed Jan 02, 2013 10:10 pm
Might be worth checking underneath to see if they haven't just put the flat sheet straight over the top of the original floor. Could be some nasty things in between otherwise
