It is currently Sat Jun 28, 2025 3:55 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon May 23, 2011 3:59 pm
Just went and had a look at mine. Compared to the pics mine is in reasonable original condition although not concourse by any stretch of the imagination. The aircleaner has been pressing up against the sound proofing for 40+ years and has gouged abit of a line across the soundproofing but no sign of any moulded depression for the aircleaner.
Its worth noting that in my first S, 1966 build, the aircleaner didn't touch the soundproofing at all. Well that's my memory of it as I was always a bit p'd off that it did on the 68.
Regards
RonR
68 build Mk1 Cooper S
PostPosted: Mon May 23, 2011 6:27 pm
here's mine... doesn't appear to be yellow, but may have been spraypainted. It is very fine though
PostPosted: Mon May 23, 2011 7:18 pm
Mine is like this too!
PostPosted: Mon May 23, 2011 8:15 pm
I wonder if it's asbestos :shock: :?
PostPosted: Tue May 24, 2011 12:50 pm
Ive still got the Glue under my Bonnet aswell, but no felt left :cry:
PostPosted: Tue May 24, 2011 9:12 pm
:shock: Cough, cough!
PostPosted: Thu May 26, 2011 9:19 pm
Better photo, does this look like the Cooper S stuff?
That is the same material (hessian backed underfelt) used for insulation on the underside of the rear parcel shelf on Cooper and Cooper S models.
Anyone know if this material is still available?
PostPosted: Thu May 26, 2011 10:02 pm
Could just spray some hessian to look just like that.
PostPosted: Thu May 26, 2011 10:09 pm
Hi John,
Call me when you have them :wink:
PostPosted: Fri May 27, 2011 9:58 am
brett wrote:
Hi John,
do you know something we don't know??
PostPosted: Fri May 27, 2011 10:24 am
Is it the same as the Hessian used on the underside of the turret?
PostPosted: Fri May 27, 2011 10:29 am
No just wishfull thinking :cry:
PostPosted: Sat Dec 15, 2012 12:40 pm
Reviving an old thread....
Has anyone found out anything about these since this was last discussed?
Anyone come across or found out what they were made of? etc
PostPosted: Sat Dec 15, 2012 1:54 pm
Yes.
According to the factory drawing:
Material: Phenolic resin bonded fibreglass uniformly coated with neoprene paint to bind loose glass fibres.
Density 4 - 6 lbs per cu. ft.
Interlaminar adhesion 0.25 lbs / sq. inch minimum
Phenolic resin 15% nominal by weight
No idea what the above description means in practice. I think there's a few people on here with reasonably unmolested originals that could perhaps be used as a template if someone wants to investigate having them made. I reckon there's a worldwide market (i.e. those wanting to complete a concours restoration of a Cooper S).
PostPosted: Sat Dec 15, 2012 3:58 pm
WOW! ok atleast we all know what it is now..
Does anyone knows what it is know if you can buy this stuff anywhere?
