It is currently Wed Jun 25, 2025 4:27 pm
 Post subject: GR 998 +80 pistons
PostPosted: Tue Oct 16, 2012 10:46 pm
Hi all, Anyone running the GR pistons on a 998 at +80 with 10 tho off the top and a 6cc dish in them?
Do they standup to some boost say 12PSI with one of ben's kits?
thanks for any help
Graham
998 SC12 61atw
PostPosted: Wed Oct 17, 2012 6:46 am
Oh dear, worry, worry...
Hi Graham
Got your message why would you want to machine a dish in them we run them with 12 lb boost with 10.5 / 11.o to one with out any problems, with a std head and .060 over size you'll only be around 9.5 to one which will not be a problem.
Graham Russell
PostPosted: Wed Oct 17, 2012 8:57 am
Hi GR Im running suck through one of ben92's kit so I don't have the luxury of an inter- cooler I do run a bit of water from 5 psi, I currently run 8.7:1 on standard 998 pistons...
How will this effect them, surly I need the cr to be a bit lower than in the 9's
Thanks for any help as I need to place the Order ASAP.
Graham
998 SC12 61atw
PostPosted: Wed Oct 17, 2012 9:28 am
I have done some quick calcs as I don't have the head with me at the mo but if I loose the 6cc in the std pistons the cr jumps up from 8.7:1 to 10.92:1 as I say if I have my maths correct...
That on a 998 with a 296 head with 25cc I the head.
998 SC12 61atw
PostPosted: Wed Oct 17, 2012 8:23 pm
Hi Graham
With plus .060 you will be around 10.1 to one
at plus .080 you will be around 10.3 to one.
Not a problem on 12 lb boost.
Graham Russell
PostPosted: Thu Oct 18, 2012 3:59 am
GR sorry to go on about this point but surly 12PSI with the CR in the 10's is way too high when you cant intercool the charge? The intake temps will be hotter than the sun? and give me liquid pistons?
The question is that I'm happy with 8,7:1 and it has been proven with std pistons on my car.
Can I put a 6cc dish into the piston or will it remove too much material for them to be stable?
Thanks for your help
998 SC12 61atw
PostPosted: Thu Oct 18, 2012 6:09 pm
Hi Graham
10 to one will be fine, have faith, get your timing right no worries.
If you melt them i'll give you a set for nothing :D
Graham Russell
PostPosted: Fri Oct 19, 2012 3:06 am
GR were you using a rotex charger? which seems to help with the higher CR?
Also what timing where you using on boost. I have megajolt so can set it to what ever I wnt, but dialing too much out defeats the object?
Going to make a purchase tomorrow........
Still want to stick a dish in them...
998 SC12 61atw
PostPosted: Fri Oct 19, 2012 9:19 am
Why don't you just call him? :wink:
PostPosted: Fri Oct 19, 2012 4:50 pm
I'm in the uk
998 SC12 61atw
PostPosted: Fri Oct 19, 2012 4:51 pm
I'm in the uk and the contact us section of his website didn't work?
998 SC12 61atw
PostPosted: Fri Oct 19, 2012 4:54 pm
His number is +61 2 96302195
PostPosted: Sat Oct 20, 2012 4:15 am
Well I have ordered some +80.. Looking forward to some 1060 action
998 SC12 61atw
PostPosted: Sat Oct 20, 2012 12:41 pm
That sounds like a dare!
Go on, go on, more boost, you can do it.....
PostPosted: Sat Oct 20, 2012 9:44 pm
Well they have been ordered from Calvert st the uk stockist... Block is being bored. No going back now!
998 SC12 61atw
