It is currently Fri Jun 27, 2025 1:11 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Oct 13, 2012 11:54 pm
Slo998 wrote:
Swiftune do some really nice parts for small bores. They are not the cheapest place around, but I've used lots of there stuff and can't fault any of it. Can't say the same for some of the other OS suppliers!
I'm using there drop gears for a 998.
http://www.swiftune.com/Product/475/swi ... -1041.aspx
They have 998 con rods that are porn!
http://www.swiftune.com/Product/757/swi ... s-998.aspx
Std ones will be fine thought, just do the normal things of polishing, shot peening, balancing, lighten if your really keen and I doubt you will be able to kill them  :wink:
My 998 build is getting very close to running again, should be a good test of how strong small bores can be. Or be a catastrophic fail :lol:
Nathan.
Glad to hear its nearly running again :)
Those rods look good, it's good to know that they're available
PostPosted: Mon Oct 15, 2012 3:42 pm
Nathan.
SH Engineering also have a bit of 998 stuff once again lots of $$$
http://www.shengineering.co.uk/sh/content/saenz-conrods
also have Omega pistons
http://www.shengineering.co.uk/sh/content/pistons
Very nice stuff 8)
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Mon Oct 15, 2012 5:35 pm
Nathan.
Very nice stuff 8)
Beanie
saenz conrods wrote:
To sum up. You get what you pay for. If it's cheap, there's a reason.
I couldn't agree more. I recently sat down and worked out the cost of machining a set of rods (from 4340 billet)... Before I could put any kind of margin on it, it was going to cost more than a lot of the rods I've seen on ebay for mini's such as these http://www.ebay.com.au/itm/200768797226 ... 38.l2649... infact it was going to cost more than that set.., and that was doing them at work paying the boss only $70/hr for use of two cnc's and the grinder!
There is a good reason Corrillo, Argo, and Scat, Eagle Crower etc are charging $300-$400 per rod. It cost that much for quality materials, and it cost that much for quality machining.
I can't comment on the materials that a lot of these cheap conrods are made out of. I haven't bought a set, I haven't had them tested. But if it's anything like the "Engineering Grade Steels", a lot of asian countries are using in Tooling and other engineering industries, then I'd say pull the rods out of your Briggs & Stratton lawn mower and use those. They'll probably last longer.
But, like I said, I haven't tested had any of them tested. And these days, China, Taiwan all those countries we've all learnt to turn our noses up at are actually producing quality goods. The good shops are usually owned and run by overseas companies in the USA and Europe, who're manufacturing in these countries because labour costs are cheaper. The good thing is that they are heavily scrutinised by their western owners, hence why the quality is better... the bad thing is that you pay more for goods out of these factories... but its only dearer compared to other asian countries, still cheaper than the west.
But when it costs the best part of $450 just for materials of known quality for a set of 4 rods, I really have to wonder what you're buying for $600.
PostPosted: Tue Oct 16, 2012 1:18 am
Western owners? What are they? :D
Most of this factories are locally owned I'd guess, but are contracted out to different companies, apple gets their stuff made by Foxconn, such is the relationship they allow apple to be elbow deep In the facility for quality control.
Interestingly, a member was arranging a group buy for alibaba forged rods for the g13b (redlinegti.com) but the members were unsure, and decided spool rods were the safer bet.
Comparing descriptions and photos of the rods side by side (and the fact the company would engrave your logo for free) I would say they were the same Manufacturer for both brands. One had spool engraved the others had no brand logo.
PostPosted: Tue Oct 16, 2012 6:26 am
I was just having this conversation with someone last night. Often what eastern manufacturers will do is purchase a well selling product, one that has already been designed and developed else where, and simply make a carbon copy of it. Design wise, they'll be identical. Whether or not the material quality is there, whether or not there is consitancy in the material used, whether or not they are machined on spec every time (quality control is not always there) is a whole other story. A close friend of mine was working on windsor which came to him for a rebuild, the push rods in it were aftermarket ones out of china that were meant to be hard chrome tipped. They were worn down to nothing in less than 10,000km. Side by side with other push rods, they looked identicle. But the metallurgy just wasn't there.
The particular industry that I work in, I deal with eastern manufactured production Tooling a lot of the time, I and can say with absolute confidence that a large percentage of them wouldn't know their nose from their elbow when it comes to metallurgy or tolerancing. It's not just a case of me being some sort of xenophobe, like I said in an earlier post many of these factories really are getting quite good at manufacturing quality gear. So I'm always willing to keep an open mind. But I just know from experience that you will often order something that is meant to be made of X grade material, it's little better than mild steel if you're lucky. You wouldn't want to buy conrods that were meant to be made from a material with a UTS of 1000MPa and then find out after you've written off your motor that they're made out of something that barely scrapes in at 360MPa. And often its difficult to even do any testing, becaue the consistancy in the material quality can be so eratic that you could have 12 identical looking components and after testing find out their made from 12 different material specs.
I'm always going to be cautious when presented with something that costs 1/3 what you're paying for a time tested and quality product... not to say that the part that's 1/3 the price is going to be crap, not at all. I'm just cautious.
PostPosted: Tue Oct 16, 2012 1:30 pm
In theory...
The Chinese in particular are being trained in Australian universities and are getting Australia's raw materials for cheaper than an Australian firm can due to FTA and other economic nonsense.
And dont have Australian minimum wage and unions and general sense of entitlement forcing up the price of labor.
And their manufacturing plants and techniques are more modern.
And then Australians buying these products have a very good exchange rate.
So they could in theory make a comparable product for less.
But in reality (or at least in niche British car parts) they make the cheapest product possible and the vast majority of people shop on price alone so will buy it and so it keeps getting made.
I would very much like to buy a good Chinese product, especially if it is cheaper than the competition. But experience has taught me if it looks to good to be true then it probably is.
just my 2cents
But to bring it back on topic and to ask the obvious, Why not just source a 1275 if performance is a concern?
PostPosted: Tue Oct 16, 2012 7:10 pm
Oh dear, worry, worry...
Hi Phat kat
Alex you seem to have a thing about rods for $600 or there abouts its very clear you don't know what you are talking about,lets start with the rod that Lindsay and i sell we have sold over 50 sets so far and not had any fail, they have been used in high out put turbo engines Group N cars running to 8500 rpm and all we do is change the rod bolts to ARP 2000 series which is included in the price, we did our home work on the quality of the steel used and the heat treatment,the steel that the chinese was or still is using in there rods and cranks is from russia old TANKS, armoured vehicles and possibly old submarines,the steel is there equivalent to our 4140 very close to our specs,also most of the roller cams used today in race applications are made from Russian steel.
If you would like to have a look in the latest FABRE flyer you will see that there are conrods there made from 4340 for Audi turbo chrysler honda mazda nissan subaru toyota for $375 with ARP2000 bolts and for anextra $254 you can get ARP 625 rod bolts,and are rated for 800 hp
They also have rods for chevs and fords made from 4340 $520 to $600 and thats for 8 rods so does this mean they are no good because the are really cheap,and they are rated for 775 hp
You must remember that these rod used in the 4 cylinder engines are rated for 200 hp per cylinder a Mini making 150 hp is making 37.5 hp per cylinder, so really a mini rod made from 4340 is an over kill like the MK1 cooper S, compare them to a cheve or a holden rod you'll see what i mean.
If you want a really good steel for rods a lot of the rod manufactures are using 300M material which is far better than 4340.
I am now getting rods made here in AUSTRSLIA that will be the price of the Chinese ones.
May be we should put the price of our rods up to $1200 that will make the better quality,BY the way our rods are not made by MAXSPEEDINGRODS.
Graham Russell
PostPosted: Tue Oct 16, 2012 9:02 pm
GR wrote:
Hi Phat kat
Graham, you still seem to have a thing about reading what you want to read and twisting what people are saying :roll: and still don't know how to address someone without sounding like you're either paranoid or wanting to start a fight.
I haven't seen the rods you're selling, I know nothing about them, I was not having a go at the product you're selling, Graham. I know nothing about them or what they cost. Relax :lol: Sorry, that's not entirely true, I was chatting with someone last night who mentioned your rods in passing and said that they have a press fit little end... Aside from that, I wouldn't be able to pick your rods out of a line up unless they had ""Graham Russell"" written all over them. And yes, Russia have always had good steel. It's reassuring that you're certain that this is what your rods are made from. Everything I posted was in loose refernce to the rods I posted in that Ebay link.
And judging by the conversations I was having via PM with people, I'm not the only one servicing the manufacturing industry who's sceptical when it comes to the quality of materials used by china
I'm not going to drop your name if you're avoiding getting involved, that's fine by me wrote:
Alex,
I'm with you on the price of those H beam rods, seems way too cheap if it's really 4340. But, who would know- the Chinese have a very laid back attitude to material specs....
Somebody here needs to do some material analysis, and perhaps a good old destructive tensile test on one, compared to say an S rod.
China (and other eastern countries) are capable of producing quality goods. I said that...
I just went through their entire site and price lists, I don't seem to be able to find the rods you're talking about. I don't surpose you'd mind scanning the flyer? 4340, so just the steel, for a total of 4 rods, was going to cost more than $375.00. I understand that obviously I'm paying local prices, and because we do nearly no smeltering here anymore we are going to pay more than Europe, Asia and the US.. And to privately import the steel wouldn't be worth it once tax and duty is put on it... Again, as I said in the posts I made in this thread...
The other bonus is the cost of materials is cheaper overseas, so it is going to be cheaper still to produce them... the thing is that there is a lot of poor quality material doing the rounds in some of these countries,,, which is why a lot the shops producing better goods are ones employed by off shore companies that heavily scrutinise what the plants are doing.
I didn't say "It's cheap its got to be crap"... I said ...
....Because.....
Phat Kat wrote:
The particular industry that I work in, I deal with eastern manufactured production Tooling a lot of the time, I and can say with absolute confidence that a large percentage of them wouldn't know their nose from their elbow when it comes to metallurgy or tolerancing. It's not just a case of me being some sort of xenophobe, like I said in an earlier post many of these factories really are getting quite good at manufacturing quality gear. So I'm always willing to keep an open mind. But I just know from experience that you will often order something that is meant to be made of X grade material, it's little better than mild steel if you're lucky.[b]
I'm not going to try and make what I said any clearer.... I don't know how :lol:
You must remember that these rod used in the 4 cylinder engines are rated for 200 hp per cylinder a [b]Mini making 150 hp is making 37.5 hp per cylinder, so really a mini rod made from 4340 is an over kill like the MK1 cooper S, compare them to a cheve or a holden rod you'll see what i mean.
That maybe, but cooper s rods don't fly to pieces at 10,000rpm when you accidently slam it in the wrong gear :lol: and even your rods (while I've been typing this I looked them up.... is this them? http://www.minis.com.au/minis/catalog/p ... ts_id=1108 475 grams is pretty good!) are made from 4140 according to the write up. The difference between the cost of 4140 and 4340 is negligible, and 4340 only just squeezes it out as far as mechanical properties go.... So you're saying your own rods are made from material that's over kill, and yet you chose to Have them made from this material... why? Because you're not an idiot
4140 comes in between 850 and 1000MPa.
4340 comes in between 930 and 1080MPa.
Graham Russell
Well, that's fine....
Yeah, Graham, I didn't post in this thread, or comment on the price of tea in china to try and hurl mud at you or anything you're selling... Until 5 minutes ago I didn't even know what the rods you're selling looked like or what they were worth. I'm happy to chat about all this, just like you and everyone else I find it interesting too. But can we all just keep it cool before this turns into another 15 page war?
PostPosted: Tue Oct 16, 2012 10:23 pm
Would you prefer to work for less than $17/hr? Is it a "sense of entitlement" which says people should have weekends off, or only have to work a 40 hour week, or have Medicare, or Superannuation, or public holidays to spend time with the family?
Your union gave that to you. Show some gratitude.
PostPosted: Tue Oct 16, 2012 10:25 pm
http://www.youtube.com/watch?v=184NTV2CE_c
PostPosted: Wed Oct 17, 2012 6:30 am
HI Alex
Iwill try to get some one to post it for you but if you give FABRE a ring and quote their latest flyer they will be only to happy to help you out.
FABRE 1300 350 351.
Graham Russell
PostPosted: Wed Oct 17, 2012 9:13 am
Thanks Graham,
Don't stress about posting the flyer, I was going to ring them for something else anyway.
Alex
PostPosted: Wed Oct 17, 2012 6:37 pm
No offense meant. Not saying that unions are a bad thing. Just that labor prices are cheaper wihtout them. At the expense of the worker of course.
The sense of enlightenment comment was that EVERYONE is entitled to the 2 car garage, big house and just generally living beyond their means in debt or on the governments dollar. Its an over generalisation but serves to prove my decadent westerns thing.
and FYI my union is a student union which hasn't done squat except demand a mandatory fee, I work a 30 hour week, plus 30 contact hours plus study. Weekends what are those? :wink:
PostPosted: Wed Oct 17, 2012 7:03 pm
Catalogue of rods I have showing $375.00 for a set of 4340 rods with ARP rod bolts. :shock:
PostPosted: Wed Oct 17, 2012 7:07 pm
Yeah nice, thats a pretty good price comopared to the $700 they had them listed online for. Great stuff.
Users browsing this forum: No registered users and 21 guests
