It is currently Sat Jul 19, 2025 6:36 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3
 Post subject: Engine Repaint
PostPosted: Mon Sep 03, 2012 1:07 pm
Location: MinisintheGong [Somewhere on the South Coast]
Be it right or wrong here's what i did:
SC degreaser, scraper and a small wire brush - nearly 2 cans. i found that the pressure pack works reasonably as a spray after loosening up the gunk.
POR15 Marine Clean, then Gerni blast got it almost clean now, a bit more with the wire brsuh in stubborn places, then repeat the POR15 and gerni had it well prepared.
Then to etch, I used POR15 'Metal Ready', and according to directions washed off. it showed itsepf to be clean and ready for paint. Air blast crevices and water trapped parts and I left it in the sun for a few hours to be baked dry.
Masked up the clutch housing and other parts not to be sprayed and then used a spray can of the selected colour from the Winnabey chart (close match) from S-Cheap for $15.99 and proceeded to empty the can on the engine.
Happy chappy with the result. :D
Again, thanks for all contributions and advice. I hope this thread helps others.
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
