It is currently Tue Jul 15, 2025 3:00 pm
 Post subject: fuel pressure regulator
PostPosted: Sun Sep 02, 2012 9:17 am
hi all just wondering where everyone mounts there fuel pressure regulator
PostPosted: Sun Sep 02, 2012 2:44 pm
If I needed one it would be up high on the firewall. But why do you need one? (unless it's turbo and blow thru carb, you then would need a rising rate regulator).
If it's an N/A car, with the right fuel pump pressure to suit the carby, a regulator is just something else to go wrong.
Also some brands are notoriously inaccurate and a waste of time using.
I hear Holley ones are OK.
PostPosted: Sun Sep 02, 2012 6:08 pm
What fuel pump do you use doc
PostPosted: Sun Sep 02, 2012 6:47 pm
I use a Facet electronic (square one) I think it's about 3 to 4psi.
Works fine with either a Weber, a Dellorto, or an SU.
I bolt them to a Mini square centre exhaust mount, then bolt that to the subframe (drill 1 hole 8mm dia). This shuts the noise up.
Note that wiring there was temporary (since weatherproofed).
Like this-
