It is currently Thu Jul 17, 2025 8:46 am
 Post subject: wheel alignment
PostPosted: Sun Sep 02, 2012 8:33 am
Hey guys I'm in need of an alignment as my front wheels are getting worn out way too quick. Being a bit of a noob what's the appropriate settings ie camber?
I'm not running any upgraded suspension or steering just the old shocks atm.
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Sun Sep 02, 2012 9:17 am
The Mini King
If It has standard Mini suspension You Can only adjust toe in toe out,
however check for bent arms and worn rubbers
 Post subject: WHEEL ALIGNMENT
PostPosted: Sun Sep 02, 2012 9:19 am
Make sure all rubber bushes are not perished or worn and suspension not too low otherwise it will be a waste of time aligning the wheels.
"Let us remove your "SHORTS"
PostPosted: Sun Sep 02, 2012 9:22 am
How can I adjust the toe in/out. All new rubbers and bushes.
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Sun Sep 02, 2012 4:38 pm
the tie rod ends on the steering rack control toe adjustment. its really something that needs to be done by a pro if your not sure as mis alignment can cause serious tyre wear and handling issues.. take it to a tyre shop and they should be able to sort it out for you
PostPosted: Sun Sep 02, 2012 6:40 pm
Carpe Diem
1967 Deluxe (Bluey)
