It is currently Mon Jul 14, 2025 12:48 pm
PostPosted: Sat Sep 01, 2012 8:56 am
Hi Guys,
Just would like some info on which wiring loom to buy new as i am doing up my 67 deluxe .Was looking at the minispares.com website and there are MK1 and MK2 wiring looms for sale.My car has an alternator so i guess the generator ones are out .
Has anyone out there had this dilemma ?As i don't know where they cross from pommy MK1 to Aussie Mk2.
Any help would be much appreciated.
Thanks
fozzo72
Jason Morgan
Mob 0409 767 594
PostPosted: Sat Sep 01, 2012 9:22 am
High heel ninja
www.vinwire.com.au
They are a Australian company that reproduce excellent wiring harnesses, tell them what you have, what you want and they will make it for you.
Doogie
PostPosted: Sat Sep 01, 2012 9:38 am
What Doogie said ^^^
The Vinwire one will fit and be correct. There are a few differences between UK Mini wiring and Oz Mini wiring... (for example, front parkers & blinkers).
Vinwire can also add options to it if you want... eg wire it for an alternator, add driving lights, electric fuel pump, etc.
PostPosted: Sat Sep 01, 2012 11:54 am
Try Somerford Mini in the UK ,address below,they do an excellent harness ,I have purchased 4 off them ,they are better than the local ones and work out at about $200 with post ,depending on which one you require . The local harnesses are around $500 - $600 .
Somerford are very helpful and can recommned which one is suitable for your mini . Scroll down to the harness descriptions and Click on the' buy now' to see the price
http://www.somerfordmini.co.uk/eshop/in ... page&id=90
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sat Sep 01, 2012 4:33 pm
I used Classic Wiring Looms. They were very helpful and very reasonably priced. All our communication was via email and phone and they happily added all the extra relays and upgraded wires and bits and pieces I wanted. Just be specific with them about exactly what you want and they'll do a good job.
Cheers, Matt
Don't be fooled, Gruhms is not my real name.
PostPosted: Sat Sep 01, 2012 10:33 pm
if you use the later looms there is more wires, eg. reverse switch, hazards.
it depends what speedo and other things you will need wires for, keep these in mind when choosing a loom, custom or shop bought.
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
