It is currently Sun Jun 29, 2025 10:51 am
 Post subject: Starter motor
PostPosted: Mon Jul 30, 2012 8:48 pm
Hi all just wondering does a Gemini starter motor fit a mini?
PostPosted: Mon Jul 30, 2012 8:55 pm
High heel ninja
Yes they do, you have to elongate the mounting holes and it bolts up.
Doogie
PostPosted: Mon Jul 30, 2012 8:58 pm
Does it mater what model
PostPosted: Mon Jul 30, 2012 9:24 pm
AFAIK as long as it's a 'real' gemini it's fine.
ie gotta be rear wheel drive gemmy, so RB's don't count. only thing an RB is good for is it's electronic dizzy module to retrofit into your TC-TG dizzy.
PostPosted: Mon Jul 30, 2012 10:05 pm
If the ring gear is a bit worn will the Gemini starter work better than the old Mini type? My theory is it might because the Gemini starter would engage the ring gear from the opposite direction?
Thanks,
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Jul 30, 2012 10:39 pm
Thanks,
You are correct Brett, you win the kewpie doll.
:lol:
geMini starter engages ring gear from the front, which is never worn.
PostPosted: Mon Jul 30, 2012 10:45 pm
Thanks Doc. I threw my Gemini bits out years ago, so I'll be stealing one from a mate soon. Much easier than changing a ring gear.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Jul 31, 2012 6:16 pm
I have a Gemini starter on my Morris 1100 if you want to have a look at one in place.
They are a very good mod.
PostPosted: Tue Jul 31, 2012 7:19 pm
The one I put on Barney-
 Post subject: Gemini Starter
PostPosted: Tue Jul 31, 2012 9:12 pm
Would the Gemini starter work on a positive ground car?
How easy is it to get one?
PostPosted: Tue Jul 31, 2012 9:44 pm
Just a matter of does the pinion gear have the same number of teeth as a mini one Ta Kiwiinwgtn
PostPosted: Tue Jul 31, 2012 10:29 pm
Bernard I don't have one handy but they are 9 or 10 teeth, same as a Mini one is.
They fit fine in pre-Verto ring gears, dunno about Rovers- probably not.
Adios57, you can buy new ones already slotted to bolt in a Mini, from
http://www.mgspareparts.com.au/
Around $160 last time I got one. These are same as a Gemini but made in that PRC place... not Japan.
[edit] I've just ordered a Bosch planetary geared starter from Convertible Mini on here for my hi-po 1360.
Cost is about $330, however I need its extra torque due to my 20°BTDC static timing (due to combustion chamber shape + camshaft type).
[edit 2] it's in now, and I'm very happy with how it spins.
PostPosted: Wed Aug 08, 2012 6:48 am
So How do you like it Kev ? I also make these for A+ engines with Verto Clutch. They have a different Drive and dimensions to mesh properly.
"Let us remove your "SHORTS"
PostPosted: Wed Aug 08, 2012 7:55 am
So what's the advantage in using a Gemini starter compared to the regular mini one??
Dusk Blue
1964 850
PostPosted: Wed Aug 08, 2012 8:11 am
Im assuming it has more guts than a standard mini one!? Ive been told to get one for my 1412cc motor, for better ease in starting.
Edit: This article might help. Yes they are more powerful and have a higher cranking speed.
http://www.moke.com.au/in-the-garage/mo ... ni-starter
