It is currently Sat Jun 28, 2025 10:34 am
PostPosted: Wed Apr 27, 2005 10:18 pm
hi
wanting to do some work on the mini k..
has a spot of rust..
could fibreglass it
or weld in a spot of metal
which would b best?
if metal, what sort?
zincalum?
how big? 1mm?
would like to kno...
(and any tips)
Kaz :wink:
kaz
hey mate, looks like your cars only running on three cylinders!
haha..funny that..
'89 toyota cressida
'71 morris mini k
66 morris van
PostPosted: Thu Apr 28, 2005 8:24 am
My preference would be to weld, Can depend on where the repair is required though.
I've used 1- 1.5mm steel sheet from my local metal supplier and got on ok. Your next question is whether to Mig or Oxy weld, again location of area requiring attention can dictate this and also availability of equipment.
Hope this helps
1965 Morris Mini 'Woody' Traveller
PostPosted: Thu Apr 28, 2005 10:50 am
thanks for reply
the bit requiring weld is the under the front windscreen - where the windscreen rubbers join.
ther are other bits but they mite just require a bit of bog.
and i was thinkin bout mig weldin, coz i think my uncle has a mig welder, that i could boro.
KAZ :D
kaz
haha..funny that..
'89 toyota cressida
'71 morris mini k
66 morris van
PostPosted: Thu Apr 28, 2005 5:40 pm
Kazzy,
I have asked a few panelbeaters and welders about this. Some are telling me that moisture can get underneath of fiberglass and continue it's nasty work. This is not a problem if you prep the area well and use heaps of resin (panelbeater mate 2005) Check out JAMS website for info on fiberglassing window edges.
My personal pref is welding, although you need the gear or money to pay.
PostPosted: Thu Apr 28, 2005 6:21 pm
Bromley wrote:
Kazzy,
If you overlap weld the mositure will more than likely get caught under there if not done properly aswell....
Personally, im thinking I will do both, although I do ahve a general preference for welding in metal in some areas. I was thinking of creating a fibreglass tire well though as the rest of mine has to come out. Still deciding on that one though
[Maverick] 1971 Mini K
