It is currently Mon Jun 23, 2025 1:14 pm
Post new topic Reply to topic  [ 281 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 19  Next
PostPosted: Sat Jun 30, 2012 1:55 pm
I was using a 2.9 with a mild 1100 and was quite happy. Combined with the standard ratios you ended up with a more useful first gear and a nice relaxed top gear and a car that was a lot quieter on a highway trip. However if you are building a motor that is happy to rev then maybe a diff ratio that allows it to rev would be a better idea.
66 Deluxe, 07 Cooper
PostPosted: Sat Jun 30, 2012 1:57 pm
That tapped hole drains the back of the water jacket.
Early cars- Morris Minor, M850 etc has a brass tap (petcock) on there.
Try and clear the hole before building the motor- a few twist drills, then hit it with a gurney.
PostPosted: Sat Jun 30, 2012 8:01 pm
Thanks Dr,
I got that one, but what about the hole that points upwards next to it, it seems to be oil?
Dalmeny
PostPosted: Sat Jun 30, 2012 8:15 pm
Holes in the block, tapped ready for plugging.
Cam shaft de-lobed.
Dalmeny
PostPosted: Sat Jun 30, 2012 9:53 pm
Thanks Dr,
Yeah it's in the oil intake to the pump, just screw a plug in as it was originally. NFI what its purpose was.
PostPosted: Wed Jul 11, 2012 11:33 pm
A little more progress. Just in case anyone was wondering I have spoken to Matt Read and he is happy for me to post the picture for this build.
Once al the holes were tapped I plugged them all with mild steel bolts and Loctite sealant. The end ones that overlap the new BMW holes. Used Matt Read cast iron plugs.
Then cut them off with a thin cut off wheel.
Off to the engine shop where the block had the deck shaved.
Marked and drilled all the new BMW bolt and water holes.
Next was to tap all the new head bolt holes.
Whilst I was in the drilling mood I relocated the oil feed hole in the head to line up with the mini block.
Back to the questions.
Q.10 Has anyone successfully machined out the front of a small bore Primary Gear to take the 1275 bush?
Q.11 Has anyone used the full floating front bush from Mini Spares?
Dalmeny
PostPosted: Wed Jul 11, 2012 11:42 pm
Is it just me or do some of the studs look out of square?
Namely the two of the left hand end?
You're so square
Baby I don't care
PostPosted: Wed Jul 11, 2012 11:48 pm
Yeah looks that way but they were only in a couple of threads. Heads been on and all ten bolts wind in nicely.
Dalmeny
PostPosted: Thu Jul 12, 2012 9:11 am
plenty of people have used small-bore primary gears & had them machined out to suit 1275 - so that`s a big yes
& also another yes with the use of full-floating front bush, they work fine, just need to make sure you have enough clearance & also make sure it`s all nice & smoothly pollished surface
you`re doing quite well Steve, keep up the good work :-)
PostPosted: Thu Jul 12, 2012 10:40 am
Yes you can machine out the front primary bush, then take another 1/8" out of the gear's bore to suit the 1275 bush. Floaty MSC bush works fine.
But once the bush is gone you need bloody good tooling to bore the gear, it is HARD! I used a ceramic insert, but these are pretty fragile.
PostPosted: Thu Jul 12, 2012 3:54 pm
Ahh, how cute, how many engines out there can you sit on a pedestal drill?! I was wondering if you were using a rotobroach, until i looked harder at the pics
I want a twinky..
looking nice.
PostPosted: Thu Jul 12, 2012 4:18 pm
This space for rent
Shame the machine shop took the engine number off when they decked the block...
PostPosted: Thu Jul 12, 2012 5:05 pm
sorry i was too slow with my reply :(
PostPosted: Thu Jul 12, 2012 7:51 pm
Dr.
Is that 1/8" an exact and accurate mearsurement for the 1275 bush, or is it an approximate and it needs to be machined to suit the bush?
Dalmeny
PostPosted: Thu Jul 12, 2012 7:54 pm
Knew it was going to happen. The BMW head covers it anyway. There has been a surface prepared on the front of the block, at right angles to where it used to be.
Dalmeny
