It is currently Sun Aug 17, 2025 1:19 pm
Post new topic Reply to topic  [ 429 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 29  Next
PostPosted: Wed Jun 13, 2012 7:21 pm
meeni wrote:
......id actually like to run the engine in the mock up front if i can to make sure all systems are go before i pull meeni apart..
Couple of jockey wheels screwed to the back of that front cut should sort that. :lol:
PostPosted: Wed Jun 13, 2012 7:32 pm
yeah ittle be like a drift machine brooo..
na just get the motor running not drive it :P
PostPosted: Wed Jun 13, 2012 8:31 pm
But think of the power to weight! :lol:
PostPosted: Thu Jun 14, 2012 5:09 pm
Test driving a front cut has been done a few times before that I know of.
PostPosted: Thu Jun 28, 2012 12:23 pm
They all look safe...
Small update, got some r1 carbies so started on a manifold for them.. They're actually a pretty cool setup to use for a mini because they can run uphill like that so the manifold length is actually reasonable
Also got a camber kit with all the goodies from the uk
PostPosted: Thu Jun 28, 2012 4:58 pm
Nice going :) .
PostPosted: Thu Jun 28, 2012 5:00 pm
AHhhhh One carbys :-)
i have a couple of sets myself,,,damn good things hey?
PostPosted: Thu Jun 28, 2012 5:36 pm
From what jve seen so far theyre great! Much cheaper then webers too! They're like a modern looking s.u, theyll look a lot better cleaned up with velocity stacks on there :)6
PostPosted: Thu Jun 28, 2012 6:49 pm
snazzy!
PostPosted: Fri Jun 29, 2012 11:32 am
Elegant and simple. EFI is nice but I'm thinking of all the wiring you don't have to worry about, and high pressure fuel pumps, return lines, sensors, ecu etc.
How do you go about tuning those things? Jets?
PostPosted: Fri Jun 29, 2012 12:07 pm
Yeah it's simpler for me and having spent a lot of money having the car wired up recently id be crazy to chop it all up, tuning wise I think most car guys drill the jets out, there's a formula to what size.. Adjust mixture screws And then sync them And then I think they're pretty right but parts are quite easy to get anyway.. They only need 2-3 psi to run too so my current fuel setup for te a series would be ample..
PostPosted: Fri Jun 29, 2012 12:12 pm
Damn sean.
This was my plan, now it will just look like i'm stealing your idea :lol:
Great minds I guess.
Aren't R1 Carbs going to be a bit big? I see a lot of 660 carbs go onto 1.3L motors
You're so square
Baby I don't care
PostPosted: Fri Jun 29, 2012 12:19 pm
I thought that at first but people run twin 45mm webers on them so I don't think it will be a drama, if it did I guess you could downsize it to a 38 or 36 mm carb of a Kawasaki or something?
Feel free to steal "my" idea ( been done thousands of times lol )
PostPosted: Fri Jun 29, 2012 1:55 pm
Not to rain on your parade(s), but if fitting a late model non- Mini engine to a Mini, engineered and all- don't you legally need to run ALL its stock emission gear (= fuel injection, cat, etc) to pass registration? :?
PostPosted: Fri Jun 29, 2012 2:18 pm
Isn't that why you change it after engineering? :wink:
You're so square
Baby I don't care
Users browsing this forum: Bing [Bot] and 16 guests
