It is currently Mon Jun 23, 2025 5:50 pm
Post new topic Reply to topic  [ 274 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 19  Next
PostPosted: Wed Jun 06, 2012 8:11 pm
adamstuart wrote:
A post way back when said it was around 60kg + plumbing
Hmmmm maybe they meant 60Kg less than a A-series...or maybe not!
PostPosted: Wed Jun 06, 2012 11:39 pm
The post read something along the lines of "90KG less than an A-Series"
You're so square
Baby I don't care
PostPosted: Wed Jun 06, 2012 11:41 pm
13secmini wrote:
Your not wrong aaron, it is bloody small, and light, as it sits here it is 65kg with gearbox.
You're so square
Baby I don't care
PostPosted: Thu Jun 07, 2012 7:29 am
yes it is correct, the engine as it sat there in that picture less the inlet manifold on my dodgy home scales was around 65kg give or take 5kgs.
Its bloody light and with all the turbo gear mounted and other auxiliaries its still alot lighter then a mini engine. When i first sat the CB80 in the mini its stance was like a 4x4 with the hilos on there lowest setting with old sagged rubber cones !!
I will get the mini on a weighbridge soon for the engineers certificate and let you know the total.
My 4efte mini was 779kg, im hoping for some where in the 600's with this one.
1974 Moke - 998cc
PostPosted: Thu Jun 07, 2012 1:12 pm
No need for an engine crane then Brad!! :shock:
PostPosted: Thu Jun 07, 2012 5:36 pm
Nope no crane, I used a block and tackle on a flimsy roof joist hehe.
:shock:
1974 Moke - 998cc
PostPosted: Thu Jun 07, 2012 7:40 pm
Well..if thats the case...handling will be brilliant...but traction a problem :shock: :lol:
PostPosted: Sun Jun 10, 2012 10:22 pm
13secmini wrote:
wow 15's :shock: Alot more wheel choices in 14 and 15 inch, plus my car has been changed to 100 pcd makes life easier.
pcd??? what's that?
I love those wheels!!!
How do you go about getting the car set up for those? With disc brakes, offset & clearance etc?
Zulu...
1967 mini Cooper S
PostPosted: Mon Jun 11, 2012 9:46 am
zulu_warrior1976 wrote:
pcd??? what's that?
PCD = pitch circle diameter.
Adam - Genuine brit not german sh!t.
PostPosted: Mon Jun 11, 2012 10:11 am
:shock:
Huh. That's all I use for an A series :D
PostPosted: Mon Jun 11, 2012 10:34 am
Why is it important? (Excuse my ignorance... I'm not a mechanical engineer)
Zulu...
1967 mini Cooper S
PostPosted: Mon Jun 11, 2012 10:53 am
PCD is the measurement of the holes in the wheels.
So the higher the number, the further apart the holes are.
So a car with 110PCD (A mini) cannot fit a 100PCD wheel.
There are a lot more wheels in 100PCD, so Brad got his car modified to take wheels of that PCD.
Everyone else is limited to a 110PCD wheel.
PS. It's actually 4x4"PCD
Which is 4 studs, in a 4" PCD
You're so square
Baby I don't care
PostPosted: Mon Jun 11, 2012 11:25 am
isn't it 101.6mm (4") not 110PCD?
PostPosted: Mon Jun 11, 2012 11:49 am
If you fit 100mm PCD wheels on a 4" PCD hub, you will introduce a bending load to the studs that they are not designed to take. You will also not be able to correctly tighten the nuts, leading to damage to the wheel nut seat in the wheel.
End result in worst case can be broken studs and/or wheels flying off - neither of which you want.
michael
yeah
110 is actually extreamly hard to get
very early mazda Rx7 ... and Daihatsu Mira/Move are 2 of VERY few cars/wheels with 4x110
