It is currently Fri Jun 27, 2025 12:07 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed May 02, 2012 6:51 pm
They will suit morris minors just fine.
But if you want TheMiniMan to build you one, why not drop a block off whilst i'm getting busy with tapping and bunging the deck. The 3 i started today must bring it up to 10 twinkies...
PostPosted: Wed May 02, 2012 8:26 pm
hee hee,,, I don`t know what i`d do without you Matty, thanks heaps man !!!!!!!
& yes i think you`re right, last count was 10x Twinkys being done here now so i spose i should change the title of this thread :-)
& yes Matt is right, we`ve already sold conversion kits to both Morris minor people & Spridget people, all still being built as we speak/type
there is a pic of a lovely goldy coloured one here somewhere with turbo charged injected 16v twin cam donk fitted, (in Sydney) & there are others
more pics to come as we get more work done on them all, it`s going crazy around here
with mega twin-cam madness :-)
PostPosted: Fri May 04, 2012 5:21 pm
haha you guys are giving me some bad ideas :P
PostPosted: Fri May 04, 2012 6:10 pm
Out of curiosity, whats the power increase with these twin cams?
PostPosted: Fri May 04, 2012 7:00 pm
well,,, it`s pretty-well double what the std-ish 5-port head gives you
now, don`t go miss-quoting me with the wrong package here,,, it`s not to say that a "decent" 5-port or 7-port etc can`t keep up with a Twinky,,, but you`d have to add some "Serious" cams & valves & inlet/exhaust systems & compression etc etc etc to the 5/7-porters to come anywhere near a Twinky...
But (funny enough) a Twinky will still be smoother & still have a far more user friendly power delivery characteristic/drive-abilty than a cam-ed up 5/7-porter
did you get that???
& ,,, if you turbo-inject a Twinky then the sky really is the limit :-)
& still be SMOOOOOOTH as silk :-) this is the part that sets a Twinky way ahead of the rest,,, it`s not just the wonderful "Amount" of power,,, it`s also the way it`s delivered
PostPosted: Fri May 04, 2012 7:09 pm
Meh.. I'm over twincams- my 25 year Italian love affair is over.
They are just needless complication.:mrgreen:
Give me the simplicity of a screamin' pushrod A series- a 5 port is fine, but go 7 or 8 port if you must! :P
PostPosted: Fri May 04, 2012 7:21 pm
hee hee,,, well kev,,, we may just have to make a trip down your way with a Twinky one day,,, Maybe on the way to hay or something like that, give you a spin in one & see what you think yeah?
it may be a long while away but i`d rather you drive one of mine (maybe my Monaco) that way you get to drive one with all the fruit :-) & besides, it`s only bucket-loads of time & money to make one,,, what else would you do with your time???, go surfing at Byron??? or race a lightweight motorbike powered hillclimb special ??? or blabber crap to mini customers all day??? lucky they`re only mini customers hey?,,, the big ones are a bit tougher to work with :-)
PostPosted: Sat May 05, 2012 4:24 pm
Yeah got all that. They certainly look the goods, Something to think about in the future I guess :wink: So many different options out there these days for the A series
PostPosted: Sat May 05, 2012 8:39 pm
They look so good in the engine bay. I love it! [/url]
PostPosted: Mon May 07, 2012 8:44 am
Looking good, Matt!
Reminds me, I should probably book my van in for a 1275. How is December looking?
Maybe 2015? :lol:
PostPosted: Mon May 07, 2012 10:47 am
hee hee, nah , it`d be a lot earlier than that, we have both Mattys here helping me,
(Matty Kosh & Matty Archer) & we`re charging ahead with the work load
without those 2 guys i`d be stuffed tho
That`d make it the 3 Matts-keteers :-)
we can do a 1275 transplant for you in a few weeks time , no problemo
PostPosted: Mon May 07, 2012 4:39 pm
I'll start sending around e-mails to source an engine, some time in the second half in the year, will be in touch!
Good to see the twincams turning out nicely, though not so good for my wallet!
PostPosted: Mon May 07, 2012 6:32 pm
I cant believe no-one has asked for a price yet, We all know how much you love that. :lol:
Dusk Blue
1964 850
PostPosted: Mon May 07, 2012 6:40 pm
hee hee, yeah well, ok, i can give a pretty accurate ball-park figure now
between $8K & $40K, depending on your wish-list & intended performance level
PostPosted: Mon May 07, 2012 10:12 pm
I have gone thru what would be required to replace as a minimum to build a Twin Kam, you would have to be able to build the gear box and engine your self and do all of the conversion work as well
I have presumed you had a 1275 engine and box in the first instance which is in good low mileage working condition.
I have used the prices from the Specialist Components site as it was easy to access and the other parts from MInisport OZ site again as it was easy to access. (that is the only reason)
The list i have accumulated is as follows
Baulk Rings (4)
Double row bearing
1st motion Shaft bearing
layshft bearing (2)
central oil pick up
rod change gasket set
Anti leak kit gearbox
Mini cross pin Diff
Diff bearings set
Centre main strap
1275 94" piston set
Thrust Washers
main bearings 20"
big end bearings 20"
camshaft bearings
Oil pump
Arp conrod bolts
A+ Rods (not included)
A+Block (not included)
A+ Crank (not included)
Mini Cam (not included)
A+ gear box (not included)
water pump
alloy radiator
lighten flywheel (not included)
lighten back plate (not included)
competition clutch plate
competition pressure plate
head bolts (10)
head nuts (10)
K1100 head / INJ
K1100 convesrion kit (SC)
twin Kam ancillary pack (SC)
twin Kam coil pack/leads (SC)
twin Kam engine management (SC)
twin cam exhaust manifold (SC)
BMW head gasket (SC)
Block machining
Crank grinding
exhaust
freight from UK
Total $6874.29 (AUD) parts only
There is no labor included at all and the engine is not even in the car yet
What have I missed
Kiwiinwgtn
Users browsing this forum: No registered users and 27 guests
