It is currently Mon Jun 30, 2025 12:39 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri Apr 22, 2005 5:48 pm
Christoph wrote:
Why did they have the two different sized ring gears? It would seem a good move to fit the 3/8 one if you want a light flywheel but then again they would probably wear out quicker :?:
Old Minis were all 1/2". Automatics were 3/8". A 3/8 can be fitted to save weight.
No it won't wear out any quicker, the bendix pinion stuffs one side of it long before either ring gear is worn out! :lol:
Note that Rover etc Minis with the Verto clutch & Lucas pre-engaged starter have a different diameter ring gear. Won't fit early flywheel.
PostPosted: Sun Apr 24, 2005 8:32 pm
Well I picked up the flywheel from the good doctor today and I've actually had time to look at it and compare it to an existing one...
Gosh! although it's still a heavy pile of metal, lots has been taken off! It even looks bling bling now :D Should go pretty good :wink:
Thanks Kev!!! :D 8)
Lillee - 1969 Morris Mini K
PostPosted: Sun Jun 05, 2005 9:33 pm
Hi Matt
why won't you modify a one piece flywheel
is the metal a different spec
Bernard
PostPosted: Mon Jun 06, 2005 12:30 am
Found something that may interest a few people....
(Courtesy of www.minis.com.au )
PostPosted: Mon Jun 06, 2005 6:52 am
kiwiinwgtn wrote:
Hi Matt
Bernard
Graham Russell and I both lighten the 1 piece and 2 piece ones the same way for road use, the material spec of both is good old `grey cast iron'.
The 1 piece finish up slightly lighter.
The 2 piece just has a steel centre hub.
:wink:
PostPosted: Mon Jun 06, 2005 12:55 pm
i`ve seen quite a few STD (un-lightened) one piece flywheels crack right through the guts of em,,,right across the keyway slot ,,,YUK!!!!
so, i`d hat to have one of them let go & make love with my groin
