It is currently Sat Jun 28, 2025 12:59 am
 Post subject: Needle and springs
PostPosted: Tue Feb 21, 2012 6:46 pm
Where would be a good starting point for needle and springs for a pair of 1 3/4 su's on a 73mm stroker 286 kent cam and a GR mild head
PostPosted: Tue Feb 21, 2012 7:02 pm
Not sure about twins, but with a single HS6 on a GR manifold, an OA6 needle and red spring worked for me.
This was on the 1412 stroker, dyno figures are in my sig below.
These needles are also used on a Healey 3000, so do work with multiple carbs.
[edit] Vizard's yellow book says for full race 1275 only, use red springs and RR needles.
