It is currently Fri Jun 27, 2025 8:20 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 16, 2012 10:14 pm
mini_mad_matt wrote:
Yep i think the only difference between putting it on a small bore and a big bore is the stabaliser bar, which you can get the appropriate one from '92'
don't need the stabiliser bar if you have a remote change
You use your exhaust, but i believe you need to trim the flanges a bit to squeeze the inlet manifold in.
Ben's manifold has the flanges on the outer exhaust ports going all the way around the stud, so you need to cut the inner ears off the outer branches the exhaust manifold flange
PostPosted: Fri Feb 17, 2012 7:42 am
well im glad the interest is there, but im sorry to say ive been talked into hanging onto it, atleast for the time being to see how i feel about driving the mini around in its naturally aspirated state, BUT keep your eye out, im still fairly certain i will get rid of it.
PostPosted: Fri Feb 17, 2012 10:14 am
yeah - sure... you won't want to go back to NA - I wouldn't want to go back, the boost is too much fun :D
