danidad wrote:
I hate plastic tanks on alloy rads-
1. Ford Probe, son's car- (Mazda rad) rad was fine, gasket leaking under plastic tank... nope, no repair kit available..
New rad is only $750 or so.
2. Ford Laser `92 (Mazda rad)- top tank cracked where the idiots designed a groove for the overflow hose to clip in it.
It just fatigued.
Had to get a changeover rad, but the core was fine- Natra said "Oh this is a common problem".
Bastard designers..
3. Ford EA, repeated overheating only when I had the boat in tow.
Bloody 2 core alloy rad was clogged "Oh yes this is a common problem". crap I've heard that phrase before..
So I put a REAL brass 3 core (taxi) one in. No more problems.
Soooo, youse can all keep your &^$%$&* alloy rads..
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
