It is currently Sat Jun 28, 2025 6:19 am
 Post subject: Rear Brakes
PostPosted: Thu Apr 21, 2005 6:58 am
Fitting rear disks are for me, I'm fixed on the idea so looking for some assistance. Do my fellow members have any leads or contacts in the motorbike wrecking industry?
PostPosted: Thu Apr 21, 2005 10:09 am
sorry no..but im impressed by the sound of this post already
PostPosted: Thu Apr 21, 2005 10:16 am
minisport in SA were selling an alloy caliper rear disc kit for Mini's.....
:shock: very expensive, but if you have the cash, then why not!
PostPosted: Thu Apr 21, 2005 7:08 pm
If you check the 16 valve mini forums, one of the guys there has used swift GTI rear discs - had to modify the rear spindles, and fitted the swift bearings, and I don't think it would fit under 10's...
I'll try and dig up a link...
Here ya go: http://www.16vminiclub.com/forums/viewtopic.php?t=2457
 Post subject: the theory
PostPosted: Fri Apr 22, 2005 11:02 pm
Looking at fitting 2 calipers per disk, one for the pedal circuit and one for the hand brake. Need to find opposing piston calipers as they and made in 2 halves and so can have a "spacer" fitted to suit the thickness of the rotor used. Finally need to machine the mounting points of the mini rear hub to allow the new rotor to be clamped to the rear of the hub stud face. Running a hydro hand brake seems to be legal if on its own circuit.
Back to the qu, anyone know a motorbike wrecker?
 Post subject: Re: the theory
PostPosted: Fri Apr 22, 2005 11:17 pm
I don't think so! I can't think of any production car with a hydraulic handbrake.
The handbrake must be a fail safe system. Hydraulics are not classed as fail safe. Look at any type of machine with hydraulics and you will see some sort of safety catch.
You do not get under a car supported by a hydraulic jack do you? Not unless it has stands as well. It is the same sort of thing.
PostPosted: Fri Apr 22, 2005 11:30 pm
Preciate the words, was hoping to give a clear picture of where I'm heading with the brakes so I didnt get people leading the thread on their own merry way.
Anyone know a bike wrecker?
PostPosted: Sat Apr 23, 2005 7:02 am
Many American cars use a foot pedal (hydraulic) park brake. These were not legal here for years, but I'm sure the rules are different now as I've seen cars here with it fitted. You need to ask RTA etc. :wink:
 Post subject: grr
PostPosted: Sat Apr 23, 2005 7:20 am
Guys! Please!
this is the mods section and I'm going to built this thread on the production of rear disk setup. I apreciate the concern on legality but not here please, place it in you own post.
Anyone know a bike wrecking shop?
PostPosted: Sat Apr 23, 2005 4:29 pm
Try Subaru front calipers too. Something like 80s model Leone, Brumby etc. Some of those had park brakes that operate on the FRONT wheels so the calipers are both hydraulic and cable actuated.
I think some models of Magna have similar calipers but operate on the rear, not the front.
Time to do some scratching through your local wreckers :twisted:
Damo.
PostPosted: Sat Apr 23, 2005 4:44 pm
Try Fiat 124 or 125 single piston rear calipers. Had a cam operated integral handbrake that pulled the pads into the disc. Similar to EA Falcon, but smaller. 8)
They are Bendix design- some other euro cars used them too I think.
<edit> These are ALLOY... 8) Bling!!
Last edited by drmini in aust on Sun Apr 24, 2005 5:58 pm, edited 1 time in total.
 Post subject: Thx for the words
PostPosted: Sat Apr 23, 2005 7:47 pm
Will follow up on both leads, I'll post my findings
PostPosted: Sun Apr 24, 2005 10:04 am
early subaru """FRONT""" calipers have handbrake facility
yep,,,front caliper,,,& there is an alloy caliper avaliable too
PostPosted: Sun Apr 24, 2005 8:44 pm
here is a pic of a KAD rear alloy trailing arm and their rear disc' attached:
Yay, finally I am using these stupid amounts of piccies i have 8)
68matic: "i havent seen much head in my life "
 Post subject: wow
PostPosted: Mon Apr 25, 2005 10:10 am
They look fantastic and if I could buy them for under $300 I would , I try to apply more brain and less wallet. That's why I'm looking for the bike industry lead.
Users browsing this forum: No registered users and 32 guests
