It is currently Sun Jun 22, 2025 2:38 pm
 Post subject: Cooper S Oil Filter
PostPosted: Mon Nov 21, 2011 8:24 pm
Hi All,
What was the original oil filter for a 1969 Australian Cooper S?
Was it the small diameter tin can type?
Or did they have the aluminium can?
Did the head have the oil filter bypass switch (that was not wired up)?
Thanks in advance.
PostPosted: Mon Nov 21, 2011 8:29 pm
Small dia tin can, (the Purolator head one)
no pressure switch on filter head,
filter was felt, not paper element.
PostPosted: Mon Nov 21, 2011 8:44 pm
My 68 has the small dia Purolator one with the oil filter bypass light switch and an aluminium can. Plus it had a felt filter.
PostPosted: Mon Nov 21, 2011 8:57 pm
OK, you are probably right then. I sold mine 20 years ago... :lol:
PostPosted: Mon Nov 21, 2011 9:01 pm
R2053P is the replacement filter - I remember that bit
PostPosted: Mon Nov 21, 2011 9:03 pm
Purolator with switch, but I thought it should have the tin can, not aluminium.
PostPosted: Mon Nov 21, 2011 9:09 pm
I was wrong! It is a pressed metal can... (I just dived out to the shed with a camera just for you!)
And if it wasn't so late I might have focused the camera.
PostPosted: Mon Nov 21, 2011 9:16 pm
Thanks for the info.
I think the aluminium was on one of the Cooper's or 850's - not sure
PostPosted: Tue Nov 22, 2011 8:55 am
HYL103 was the genuine felt part number (from my horribly aging memory)
who are you anyways & why are you typing into my microwave oven?
PostPosted: Wed Jan 18, 2012 9:56 am
Resurrecting a thread from a couple of months ago. . .what are the applications of these three Purolator filter cases? All three have pressed metal cans (not aluminium) and all three are small diameter.
1. Has a bypass switch. . .sounds like this one is Mk1 and early Mk2 S?
2. Bypass switch boss but no actual switch.
3. No boss or switch.
Any ideas?
PostPosted: Wed Jan 18, 2012 10:09 am
The last one was definitely on 850, and maybe on early Cooper.
PostPosted: Wed Jan 18, 2012 11:09 am
Thanks Doc. . .I'm hoping that the one with the boss but without the switch is for a later Mk2 S. . .'cos that's what I need. . . :)
I didn't realise I had so many of these things lying around until I went looking.
PostPosted: Wed Jan 18, 2012 11:51 am
Online
My unmolested late 1970 MKII S has number 2 version fitted.
PostPosted: Wed Jan 18, 2012 2:56 pm
Just had a look at what our 4th month 1970 build Mini K has, we have had it from new. looks the same as number 3 version but to my surprise when I rubbed off a bit of the grease and crud it has RYCO cast into the filter head. Always thought it had a Purolator filter. Apart from the name it looks the same as the Purolator one in pic 3.
PostPosted: Wed Jan 18, 2012 3:16 pm
Ryco were used on the K, Morris 1100 etc as they were Australian made.
But Cooper S motors were built in UK and shipped here complete with filter.
