It is currently Fri Jul 04, 2025 7:37 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Apr 19, 2005 7:22 am
call Ken at Miniautomotive about lightened flywheels. He uses the two peice flywheel centre and then gets a guy to make a whole new outer. Nice and safe and no need for spacers etc etc as these are NOT merely spun an a lathe and drilled.
PostPosted: Tue Apr 19, 2005 7:17 pm
Christoph wrote:
I cannot decide whether to go steel or just get a stock one machined down and balanced. I suppose machining a stock one would be a fair bit cheaper... how much lighter are they?
I machined Chong's flywheel ( 2 piece) today- 0.200" off the outer face, then another cut 3mm from ring gear, down to the edge of the 3 slots. As I usually do.
Nothing taken off the inner face (engine side).
Forgot to weigh it standard- but with the standard 1/2" ring gear, it finished up after machining at 6.3Kg. :wink:
PostPosted: Tue Apr 19, 2005 7:56 pm
should have weighed the shavings :D
1974 Moke - 998cc
PostPosted: Tue Apr 19, 2005 8:02 pm
Yeah right... they are all over the lathe at work, and the floor, and... and... !!
Nah... too much cleaning.. not my job! :lol:
PostPosted: Tue Apr 19, 2005 8:06 pm
HA hA busted,, working on minis while at work, we all know you only go in to work to use all there equipment :D
1974 Moke - 998cc
PostPosted: Tue Apr 19, 2005 8:09 pm
I do it in my lunch break... :shock: 8) :wink:
Anyhow.. the boss is a Mini lover, he owns more than you and me! 3x 1275LS for a start.
BTW he wants a look at yours, next time you're up for a run. :lol:
PostPosted: Tue Apr 19, 2005 10:50 pm
:lol: Dr Does fine from home....but the rest is a bonus 8)
I can give you two or three (stockies) on the weekend to weight up :lol:
You mentioned the three Mini's... :twisted: whats he doing with the Kart
PostPosted: Wed Apr 20, 2005 1:27 am
I know where there is a pile of 22G270's - ready for modification :wink:
And yes, I agree with doc, dont do it to the other castings.
PostPosted: Wed Apr 20, 2005 2:03 pm
Yeah i'd be interested in how much the standard flywheel weighs... I think it's either 9kgs or 7kgs...
PostPosted: Wed Apr 20, 2005 7:11 pm
I'll guess at 9kg.. going by what I took off it.
I'll weigh one at work tomorrow. :wink:
Vizard says the std Mini flywheel & backplate together weigh 28 lbs (12.73kg)
PostPosted: Wed Apr 20, 2005 8:24 pm
You took that much off it?! 3 kg! :shock: gee ...
PostPosted: Thu Apr 21, 2005 3:05 am
Wow, yeah 2.7kg's IS alot more than I had ever thought you would actually be looking to remove...
I can imagine quite an increase in performance with THAT much weight reduction..... nice!
*Edit... just read Vizards explanation on "reduction of gyrating weight Vs reduction of vehicular weight" (pg 127 of "HOW TO MODIFY YOUR MINI") -mmmmm impressive :shock:
PostPosted: Thu Apr 21, 2005 8:46 am
ok,,,these little beauties are "the Bling" when it comes to lighgtened flywheels, without costing an arm & a leg for a full steel job,
I did my first one when i was about 16 years old & i still have it in my race motor to this day, (working that out it`s now done approx 26 years of Mad Matt abuse, that would be about 500 years of "normal" person abuse :-) )
i can`t count how many of these flywheels i`ve lightened & not one has given any trouble """EXCEPT""" for one guy who simply didn`t know what he was doing when setting it up & he got the centre all cocked up, flywheel still didn`t fly apoart, just simply wobbled, a friend of mine bought it off him for $20 & has since re-centred it & is now in his 1470cc turbo motor :-)
Ken nelson , Fred Sayers, Henry Draper, My dad, & soooo many other people have bought thses flywheels & still no problems,,,i`d "guestimate" that approx 300 plus of these flywheels are out there in the mini world.
They are all CNC machined, that is,,,we did the program to run em & now days we just bolt em down, centre them & hit the go button,,,all of em are exactly the same cutting
easy-peasy
My race mini saw 9000rpms quite regularly at speedway from about 1982 to about 1988, that`s a lot of revs , for a long time, in a very hard yakka type of racing, nearly every saturday nite, then it did a number of years on the race circuits up here, Lakeside, Morgan pk, Willowbank etc including all the hillclimbs & autocrosses that i do & then it hit Targa Tasmania for 2002,,,you just won`t fault them simple as that,,,they remain quite thick, no "thinning" down at all,,,just CNC machined out 3 big scollops & then another layer of 3 big scollops
finished weights depend on the original flywheel used,,,there are quite a few different castings, some thicker than others to start with, but generally a finished flywheel can end up at about 5&1/2 - 6 kgs
i personally use the competition steel back plate,,, but we set these up for road use as well & a std back plate is quite ok
they cost $150 "EXCHANGE" for your std "2 Piece" flywheel...
I WILL NOT LIGHTEN THE LATER STD ONE PIECE ITEM!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PostPosted: Thu Apr 21, 2005 9:16 am
NAV-MAN
OOOOHHHH i got a two peice flywheel so i'll keep that in mind when i build my next engine
PostPosted: Thu Apr 21, 2005 5:00 pm
That makes very interesting reading Miniman!
Here's hoping it will be! 3kilos is HEAPS! I was thinking shave a few thou off here and there for a few grams :lol: :lol:
