Minster, umm I don't think the air con is a goer (IMHO) at least not in the form presented in the starlet. The whole system takes up a lot of space, which you have in the Starlet but definitely don't have in the Mini. For instance the compressor for the aircon sits just above the oil filter. Given that you have to remove the alternator from the back, if you leave the compressor for the air con where it is where do you put the alternator. Also it isn't just the engine side that is the problem, the air conditioning system in the cabin is huge and will mean that you and probably your passenger will have to adopt the fetal position while driving
. Then there is the air con radiator, where do you put that, especially if you want to keep a FMIC.
Then there is the...
Also trust me in a roundnose you would have to relocate the turbo to somewhere else unless you extend the frount! Or you get a clubby.
225hp atw on 14psi. 1/4 Mile no idea. Take one 1971 Mini Clubman, one Starlet GT Halfcut, Simmer over a warm MIG Welder, and Voila Minstar!
www.mpdesign.id.au
