It is currently Sat Jun 28, 2025 4:52 am
 Post subject: dizzy movement
PostPosted: Sat Oct 01, 2011 1:35 pm
hello my name is jamie i am fairly new to working on my new mini, my question is ,my mini when you grab the dizzy it moves about 15mm each way and about 10mm in and out is this a common fault ?? is there a qick fix?? your advice would be much appreciated
PostPosted: Sat Oct 01, 2011 2:18 pm
Tighten the hold down clamp :D
 Post subject: Re: dizzy movement
PostPosted: Sat Oct 01, 2011 5:08 pm
Are you talking about the whole distributor, or if you try and move the rotor button inside?
Dicko.
PostPosted: Sun Oct 02, 2011 9:31 pm
whole dizzy
PostPosted: Mon Oct 03, 2011 8:45 am
purpleminik wrote:
whole dizzy
See post 2 above ^^
The clamp will tighten around the Distributor and bolt to the block.
Dicko
PostPosted: Mon Oct 03, 2011 3:19 pm
In some cases due to previous overtightening, the dizzy's alloy shoulder inside the clamp breaks. Then the clamp doesn't work.
This applies to early dizzys that are hollow inside there, later ones (45D etc) are solid.
There are a few ways to fix this, there was a thread here recently.
I fixed a Cooper S one recently by machining the shoulder down and shrinking an alloy ring onto it.
 Post subject: Dizzy
PostPosted: Thu Oct 13, 2011 9:44 am
Reading the above.... The solution would be to buy a new Dizzy from me and might be an idea to go the modern way.... electronic.....
"Let us remove your "SHORTS"
