It is currently Mon Jun 23, 2025 5:08 pm
Post new topic Reply to topic  [ 99 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
PostPosted: Sun Aug 28, 2011 4:14 pm
_666_ wrote:
i was under the impression that the allspeed fit roundnose minis without firewall mods (assuming you sort out a modified inlet) ?
If you do sort out a modified inlet (I assuming the modification required is probably cutting and shortening the intake runners, or fabricating a new intake all together) make sure it looks legit and original, and make sure it is very hard to notice that it's been modded. Then don't talk much about it on here as modified intakes (appart from FMIC on turbo motors to avoid the need for a bonnet scoop) are a no no. Transport SA does not like modified intakes on modern engines.
PostPosted: Tue Aug 30, 2011 8:46 am
So, am thnking a JDM B16a with an allspeed subframe in a roundy with a fibreglass flip front...
Or a JDM B16a with an allspeed subframe in a clubby...
Thoughts?
Zulu...
1967 mini Cooper S
PostPosted: Tue Aug 30, 2011 1:55 pm
Be careful with the flip fronts, depending on the engineers some say yes some say not a chance. They don't really like the thought of a whole removable front
Life's a garden.... Dig It!
PostPosted: Tue Aug 30, 2011 2:55 pm
Die Die Die!!
Personally I'd be going for a TB18 type r, with the all speed frame and a solid steel flip front and then turbo it after engineering
PostPosted: Tue Aug 30, 2011 3:29 pm
Clubman or Roundy?
Zulu...
1967 mini Cooper S
PostPosted: Tue Aug 30, 2011 4:41 pm
Either way check first to see if it will be road legal. NSW had (I don't know if they still do) engine size to weight limitations... 1.8 turbo would never have passed
PostPosted: Tue Aug 30, 2011 4:56 pm
Milatsmadmini
luckily this bloke is in australia's mexico... he can get away with anything! :lol:
PostPosted: Tue Aug 30, 2011 11:32 pm
Die Die Die!!
Roundy :)
PostPosted: Wed Aug 31, 2011 8:30 am
Love it!!! (Tequila Anyone??)
