It is currently Wed Jun 25, 2025 11:09 am
Post new topic Reply to topic  [ 99 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject: wrong place
PostPosted: Sun Aug 16, 2009 2:55 pm
_666_ wrote:
Harley wrote:
Anything is possibly if you put your mind to it.
It's possibly you've revived a two year old thread as well.
tru, but he actually linked this thread with a newer one..
and for the record..
sorry I was hoping to put this post in the conversions register not really here. ps yes the radiator is front mounted
mini regards
peter d
1st victorian road registered vtec mini.
PostPosted: Tue Aug 23, 2011 4:20 pm
very encouraging to see this conversion. I like 4efte conversions but LOVE vtec conversions...
Zulu...
1967 mini Cooper S
PostPosted: Fri Aug 26, 2011 10:42 pm
Hi Peter,
I'm interested in a vtec conversion but another member on my vtec post said they were too wide to pass the regs here... Can u add any info to the debate?
Zulu...
1967 mini Cooper S
PostPosted: Sat Aug 27, 2011 11:57 am
the off the shelf kits are too wide normally, you will have to make your own frame like peter did.
PostPosted: Sat Aug 27, 2011 12:05 pm
zulu_warrior1976 wrote:
Hi Peter,
The actual comment was that the UK kits were too wide, some of the US kits were ok, or you do like Peter did and fabricate your own.
No one said all VTEC kits were too wide.
Dicko.
PostPosted: Sat Aug 27, 2011 3:09 pm
waiting for video of it tearing up :P
PostPosted: Sat Aug 27, 2011 4:05 pm
Hi Peter,
Dicko.
Thanks for clarifying that.
Zulu...
1967 mini Cooper S
PostPosted: Sat Aug 27, 2011 4:19 pm
The best start would be to talk to an Engineer and find out their thoughts about how you should proceed. No point starting something if you're only going to proceed in the wrong direction. Get your proof of concept agreed on first then take it from there.
Dicko.
PostPosted: Sat Aug 27, 2011 5:19 pm
Thanks for your guidance Dicko
Zulu...
1967 mini Cooper S
 Post subject: vtec frames
PostPosted: Sat Aug 27, 2011 9:30 pm
Hi Peter,
the allspeed engineering uk frame gives u the correct width and has been fitted, engineered and reg here in victoria.
the firewall has to be cut a lot to get the standard b16a inlet manifold to fit and the front extended about 60 mm on a roundy. but all that said if i was doing it again i would buy it its a good price now with the aussie $ up
mini regards
peter d
ps u should check out the [ 16 valve mini club ] and go to honda forums
lots of vtec builds to look at.
PostPosted: Sun Aug 28, 2011 7:23 am
Thanks Peter,
Ok, Need to extend the front on a roundy.
What about required body mods on a clubby? Or did that fit fine?
Zulu...
1967 mini Cooper S
PostPosted: Sun Aug 28, 2011 11:55 am
Die Die Die!!
i was under the impression that the allspeed fit roundnose minis without firewall mods (assuming you sort out a modified inlet) ?
PostPosted: Sun Aug 28, 2011 12:56 pm
yes your impression is right, thats why my post said [to fit the standard b16a manfold] you will need to cut the firewall.
Zulu
some mods are needed to the inner guards in the clubman and my engine is moved forward 30mm so no need for major firewall mods.
mini regards
peter d
PostPosted: Sun Aug 28, 2011 1:54 pm
Just out of interest, did you consider a flip front for your clubman conversion Peter? Not sure if they do flip fronts on clubman shells (never seen one anyway) but thought i'd ask.
Zulu...
1967 mini Cooper S
PostPosted: Sun Aug 28, 2011 3:00 pm
Die Die Die!!
Yes but you also said it needed to be extended, I was under the impression that it fit without the need to extend
