It is currently Fri Jun 27, 2025 2:23 am
Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 13  Next
PostPosted: Thu Apr 14, 2005 2:05 am
Yep, the price was $800...... was $850 when I ordered it..... will probably be $900 before you know it....
Anything is better than paying $5000 for other kits. Even if it needs a bit of custom work, who cares.... tis CHEEEEEEEEEEP anyways
What are ya gonna do.... buy it somewhere else???? :lol:
And yep, been on the TOYMODS forum.... they are all sold at the moment. Ive got my name on 3 of em already :wink:
PostPosted: Thu Apr 14, 2005 6:46 pm
the supercharger kit is bloody fantastic. i had to post a reply even after just coming out of hosptial today after having a titatium plate out of my right arm so typing with left hand
a couple questions.. what model toyota did the sc12 come out of, how would i id by looking at it..
is the belt support wheel adjustable
what does the post with split pin do is it a release valve
what parts do i need to take of the toyota, eg drive pulley etc..
what s the best compression ratio to run for 1293 & 1380 motor
how much extra torque , hp does 6-7 pounds of boost give
keep up the good work
Bernard
PostPosted: Thu Apr 14, 2005 10:36 pm
Wot he said :P keep me informed!! :D
Someone buy me a kit, I'll buy it from you in about 6 months time! :D
77 Leyland Mini. Gulf Racing Colours!
PostPosted: Fri Apr 15, 2005 5:42 am
Okay. Will answer those questions. Remember, this is NOT my invention. The creator will let me know if I get anything wrong, but I am sure about 99% of it.
4A-GZE Toyota motor. Found in Japanese AE101 and AE92 Corollas, AW11 MR2's, etc. Best one is fitted to AE101 engines (1992-95).
Yes. It is mounted on a threaded block that runs up the square shaft up a threaded rod. Adjustment nut is on top.
Backfire pressure release valve. Spring loaded valve that expels excessive pressure created by a backfire from the head. Will prevent damaging the supercharger. Directly above that is the boost gauge outlet.
ONLY the bare SC12 supercharger. No manifolds, brackets or anything.
Lower CR = higher possible boost PSI. Can safely use anything from 7.5 to 8.5 CR. Above 8.5CR gets a bit hot. Over 9.0 is no-mans-land.
It all depends on the OTHER things you do to the motor: head work, cam, fuel type, CR, etc...... lets just say: it adds from 35-50%. Have seen a 850cc motor with supercharger (and other engine tweaks) blow away a 1275.
Superchargers will tend to increase torque greater than they can increase horsepower. Opposite theory for turbos.
PostPosted: Fri Apr 15, 2005 7:05 am
Where do I put my name down for a kit?
PostPosted: Fri Apr 15, 2005 3:44 pm
Hmmmmm........ (Steve checks Netbank to work out fundage allowances....) that is one sweet kit 8)
I got nuthin......................
PostPosted: Fri Apr 15, 2005 9:40 pm
How does the backfire pressure release valve work? I havent seen one on any other system or any of the turbo set ups do you really need it? Is this a standard crank pulley modified? Looks like a very impressive kit. What are you going to do about your bonnet? Will it fit under there?
PostPosted: Sat Apr 16, 2005 2:07 am
minster wrote:
1-How does the backfire pressure release valve work? I havent seen one on any other system or any of the turbo set ups
2-do you really need it?
3-Is this a standard crank pulley modified? Looks like a very impressive kit.
4-What are you going to do about your bonnet? Will it fit under there?
1- The force from the backfire is met by the force from the blower - the valve is the first thing that gives way. I assume the spring rate is set to allow 8 or 9 pounds before opening, so as not to lose boost.
2- Yep, dont want to damage the blower do we? Turbos have a blow off valve, it has practically the same safety feature.
3- It is a factory mini pulley (late type). He modifies it in a lathe to create the second pulley drive. Would be possible to fabricate a complete new one from scratch if you wanted a specific boost level.
4- am told it should fit if you cut the top lugs off the supercharger.... but will be damn close. Bonnet bracing may still need removing. Dont know yet.
PostPosted: Sat Apr 16, 2005 9:29 pm
Sounds good. Do you think the supercharger would get very hot? You would'nt want it to cause heat damage to the bonnet! What type of power do you think you will get out of this combination? Im still trying to make my mind up which way to go for my mini! What about tuning the carb and distributor? Will your pulsar dizzy be fine to use? Thanks
PostPosted: Sat Apr 16, 2005 10:35 pm
Have seen many a mini here and abroad that have vents or inserts in the bonnet at specific locations to vent the hot air.... so that would be a viable option, and it looks quite good cosmetically as well IMHO
PostPosted: Sun Apr 17, 2005 2:40 am
Turbos get hot MAINLY because of the exhaust gas that is used to propel it. Compressing cool air will heat it up, but not to exhaust temperatures.
Superchargers?? Hardly as much. The engine will still be the hottest thing under the bonnet.
Venting a mini bonnet will most likely make the engine run hotter, as air will escape thru these vents without going thru the radiator. Not good. A front mount radiator is best with a vented bonnet.
What type of power? HORSE power I guess....
Power increase is dependant on the WHOLE engine package.... the more mods you do to compliment it, the more you will get out of it. As a straight bolt on, it will probably get you 25 or 30 percent more. Then add a cam, head work, tuned ignition, higher octane fuel types, etc etc... and you will "release" the available power... maybe up to 50 or more percent
Carb tuning is not a problem..... if you leave it to a dyno tuning professional.
Pulsar dizzy will not be good enough in its standard form... will also need added tuning and modifying. Advance curve will be wrong.
PostPosted: Sun Apr 17, 2005 7:44 am
Bugger Ay I did not think of that :?
PostPosted: Sun Apr 17, 2005 9:12 am
Try it first as is, you may be surprised.. :wink:
PostPosted: Mon Apr 18, 2005 12:52 am
Yeah, it will be.... er.... okay.... but not perfect - just like a Lucas one :wink:
PostPosted: Mon Apr 18, 2005 1:32 am
He wont know any better then will he? :lol:
