It is currently Tue Jun 24, 2025 8:39 am
PostPosted: Tue Jul 05, 2011 9:36 pm
what are you using heaters wise?
i have a rover one but some one reckons don't bother and use a electric one?
PostPosted: Tue Jul 05, 2011 9:56 pm
Maaate, if you are a true big tuff Qld'er you don't need no wimpy heaters.. :lol:
I still run the under bonnet Minimatic heater, but I've added a blower so it works in traffic. :wink:
PostPosted: Tue Jul 05, 2011 10:06 pm
My 850 had no heater at all, and even in the dead of winter I didn't find I needed it.
My rover had the bog stocko unit, was only ever on in summer with the windows down when I needed the extra cooling. :lol:
My Deluxe is the rolls royce of the lot, its got the late rover 2 speed unit. Works well, for a mini heater. :D
I wouldn't put an electric heater in, I'd rather have a coolant leak in the car than a fire.
PostPosted: Tue Jul 05, 2011 10:36 pm
I may go for one of these.
http://www.t7design.co.uk/index.php?mai ... x&cPath=65
Alan (Mearcat) told me about them.
I think postage was like 30pounds which isnt too bad.
Worst comes to worse.. just use a 12v hair dryer?
PostPosted: Tue Jul 05, 2011 10:44 pm
well both my minis have one both not working one plumbed in one aint.
just thought it would be nice for the everyday car.
PostPosted: Wed Jul 06, 2011 6:26 am
Track pants and thick socks.. :wink: 8)
Dusk Blue
1964 850
PostPosted: Wed Jul 06, 2011 6:49 am
Heater? Heeeaaterr? What is this mythical 'heater' you speak of?
PostPosted: Wed Jul 06, 2011 8:07 am
And a thick fluffy jacket.
PostPosted: Wed Jul 06, 2011 10:33 am
I thought you had to have a heater for demisting purposes? I don't have one yet but I like to live on the wrong side of the law. Breakin the law breakin the law!
PostPosted: Wed Jul 06, 2011 10:39 am
How many watts are the electric ones? To make any difference they'd have to be pretty high wattage. At 12V they are going to need a lot of amps so big fat wires to run them, and a big alternator to power them. You are way better off using the waste heat out of your hot water, if you can.
A little back of the envelope calculation. I have a 1200w fan heater in my office, its just about able to bring the temperature up a few degrees but it would be fine in a Mini sized volume. 1200W/12V = 100A. 100 Amps, approximately twice the output of a standard Mini alternator!
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Jul 06, 2011 10:47 am
I have one of the little electric ceramic heaters.
From memory it draws about 15A x 12V = 180 watts
It's only just good enough for demisting the windscreen in a mini, forget about using it for heating the whole cabin.
PostPosted: Wed Jul 06, 2011 12:48 pm
A lot of people with retrofitted EVs use like 12v, 10-20A heaters mounted to the dash (or behind or below and plumbed in like a Mini heater) simply to demist the windscreen due to ADR requirements and a lack of cooling water (as most EVs, particularly retrofitted EVs are air cooled).
PostPosted: Wed Jul 06, 2011 1:21 pm
At risk of getting a bit sidetracked but the best bet for an ev would be aircon driven electrically, its much more efficient than just running a heating element.
EVs still have waste heat that could be used for heating - batteries and electric motors both run hot. The older model Prius we had here at work had a battery cooling duct that comes out next to the passengers shoulder in the back seat, the manual warns not to cover it or the battery will overheat.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Wed Jul 06, 2011 3:04 pm
Put a turbo in - more power and keeps the cabin nice and toasty with the windows up 8)
PostPosted: Wed Jul 06, 2011 5:51 pm
what about one of these
http://www.ebay.com.au/itm/Kawasaki-KLX ... 35aecebe3d
and one of these
http://www.ebay.com.au/itm/Computer-PC- ... 41501729a0
teamed up?
radiator may be a bit exxy but you get the idea? you'd probly pick one up cheaper at a wreckers...
