It is currently Fri Jun 27, 2025 10:58 pm
PostPosted: Thu Jun 23, 2011 11:20 pm
I've been putting together my BMW twin cam engine bits and I have almost everything but a flywheel and clutch.
I'm using an A+ 1275 block but I assume this doesn't dictate whether the clutch has to be verto or not.
The car will be almostly solely for road use. What clutch and flywheel combination do people recommend?
2008 Prado GXL
PostPosted: Fri Jun 24, 2011 6:58 am
If power output be up to about 120 HP and you're not going to rev the ring out of it, then my combination of choice would be -
* lightened std pre verto flywheel, .200" is enough
* lightened S back plate
* bonded & riveted clutch plate
* orange diaphram
If it going to make more power, the use grey diaphram.
Steve
PostPosted: Fri Jun 24, 2011 8:41 am
I agree ^^^, however a light steel backplate is more durable with the grey diaphragm (as Benjamin found out on his turbo 1152 when his lightened S backplate shattered). Perhaps it was how it was lightened though.
PostPosted: Fri Jun 24, 2011 9:23 am
Rts verto clutch proven to 200 bhp light pedal. Search on turbo minis
PostPosted: Fri Jun 24, 2011 9:54 am
Yes seen the RTS clutch on turbo minis but the DIY factor is a bit beyond me.
2008 Prado GXL
PostPosted: Fri Jun 24, 2011 10:29 am
Is anyone selling RTS clutches?
2008 Prado GXL
PostPosted: Fri Jun 24, 2011 10:33 am
no one is selling them but some one on TT would knock one up if you asked nicely
good blokes.
PostPosted: Fri Jun 24, 2011 11:02 am
Been watching that forum for years, only just realised I'm not a member :shock: .
2008 Prado GXL
PostPosted: Fri Jun 24, 2011 3:47 pm
we do a nice light package, but using a "Blue" diaph,,, gives over 1200-1400lbs clamp (depending) pressure & still fairly light on the foot
Now that pic shows it with a puck plate but a decent AP comp material plate will be fine
if you notice we use our own CNC lightened (2-piece) flywheel, but we machine & press fit a new clutch spring "seat ring" into the flywheel, which moves the spring pivot point to effect WAY more clamp-age using the blue diaph , without the problem of being heavy on the foot
pretty tricky hey? :-)
Edit--> Vertos are heavy as lead,,, no matter what you do to them & besides they`re for skinny little girls :-)
PostPosted: Sun Jun 26, 2011 5:45 pm
oi steady on matt ^^^^^ lol.
the first rts weighed 19.8 lbs all up ,an ultralight weighed 16 lbs all up ,so not that bad .
i do drive like a little girl though 8)
robert.
just try it ..see if it works .
http://www.youtube.com/user/legrandphromage
PostPosted: Mon Jun 27, 2011 8:26 pm
Dave I reckon either get a rts or drill your clutch bearings with the oil feed mod so they don't die from a heavy clutch :)
Any engining mob can do it when building the block.
Ps clutch bearings I mean something else but I cant think of the name right now.
PostPosted: Mon Jun 27, 2011 8:46 pm
i expect you meant to say "Main cap Thrusts"
PostPosted: Mon Jun 27, 2011 8:48 pm
robert.
hee hee, Hey Robert, good to see you here again, How`s the weather up there?
& yeah the RTS looks good-ish,,, i personally havn`t tried one so i can`t comment, but still to heavy for me tho :-)
PostPosted: Tue Jun 28, 2011 1:39 am
Lol that's it the thrusts.! And one of mattered ups you can't go wrong!
PostPosted: Tue Jun 28, 2011 1:40 am
Users browsing this forum: No registered users and 24 guests
