It is currently Fri Jun 27, 2025 2:52 pm
PostPosted: Sun Jun 19, 2011 7:19 pm
Will a 1100s crank fit into a 1275 A+ block ?
Do I need anything special to do it ?
Cheers Jon
PostPosted: Sun Jun 19, 2011 7:25 pm
Sure it will fit in as stroke is under 86mm, and if it's a stroker the S conrods will fit too- although there is a little less room in there than in the A series 1275 block.
Last edited by drmini in aust on Sun Jun 19, 2011 7:27 pm, edited 1 time in total.
PostPosted: Sun Jun 19, 2011 7:27 pm
Just a quick question, since things seem to be answered:
Why are you putting an 1100 crank into a big bore?
Don't have access to a 1275 crank I presume?
You're so square
Baby I don't care
1100S crank IS a big bore one. They are 1275cc.
The 12G1505 has bigger crankpins so it can be stroked 3mm like in my 1412.
Last edited by drmini in aust on Sun Jun 19, 2011 7:28 pm, edited 1 time in total.
PostPosted: Sun Jun 19, 2011 7:28 pm
1100S, Adam... It's a Morris 1100'S' engine
PostPosted: Sun Jun 19, 2011 7:37 pm
thanks for the quick reply.
73.5mm bore X 85.00mm stroke = 1443cc.
should be fun in the back of the FANG.
PostPosted: Sun Jun 19, 2011 8:01 pm
Ahh.
The 's' Was lower case, so I missed it!
Going blind in my old age, don't mind me.
I swear that clubman was brown too..
You're so square
Baby I don't care
PostPosted: Mon Jun 20, 2011 5:26 pm
NO,NO,NO,NO,NO you need to put it in the LS so next time im around i can look at it.
