It is currently Fri Jun 27, 2025 4:51 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Jun 12, 2011 8:43 pm
Thanks all for the research and the info.
I purchased a new Suzuki swift alternator as the 2nd hand ones are now getting old.
Shaved about 5mm of the bracket and fitted up all very neat.
I now need to find a better way of fitting the tensioner bracket.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jun 18, 2011 7:00 pm
Use a rose joint for tensioner
PostPosted: Sat Jun 18, 2011 7:21 pm
Where do I buy a rose joint ?
From a nursery? :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat Jun 18, 2011 7:24 pm
Mods rock!
Try a Nissan Pulsar one :wink:
From a nursery? :)
Probably the same place as a Pot Joint
But I think NG means a Rod End.
PostPosted: Sat Jun 18, 2011 9:41 pm
Yes rose joint or rod end
http://www.ebay.com.au/itm/rose-joint-r ... 2295wt_692
im going to use a rose joint!
PostPosted: Sat Jun 18, 2011 9:51 pm
And if you get a left hand thread on one of them it would be real easy to adjust. (The left hand threads were about 3 times the price when I used to get them a long time ago!)
PostPosted: Sat Jun 18, 2011 11:09 pm
yeah.... wouldn't it be a bit hard to tension it unless you do have a left hand thread on one end...
PostPosted: Sat Jun 18, 2011 11:12 pm
Probably easier with one of these...
PostPosted: Sun Jun 19, 2011 2:30 am
that is what i want morris! where can i get them in australia?
the left hand thread type sounds like a great idea just need a good size.
PostPosted: Sun Jun 19, 2011 2:32 am
PostPosted: Sun Jun 19, 2011 7:22 am
http://www.harboursidechandlery.com.au/ ... s_id=15831
PostPosted: Sun Jun 19, 2011 10:54 am
gafmo wrote:
http://www.harboursidechandlery.com.au/catalog/product_info.php?cPath=143_209_211_212&products_id=15831
that's very cheap for what it is, but $43.55 for an alternator adjuster bracket is a bit steep :lol:
PostPosted: Sun Jun 19, 2011 11:03 am
Just be aware that the one I posted is a random photo off the net. It could be made from brass and not very strong.
It would be designed for use in tension and not designed for use in compression so it really may not be very good for an alternator bracket. It does give you some ideas though!
But it does look nice! :lol:
PostPosted: Sun Jun 19, 2011 11:09 am
Yes lol
PostPosted: Sun Jun 19, 2011 7:44 pm
You would also want a nut on each end to lock it, otherwise it would wind on in again
