It is currently Fri Jun 27, 2025 2:14 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Tue Apr 12, 2005 9:23 pm
i will call them tomoro
PostPosted: Wed Apr 13, 2005 6:26 pm
Anto got one of them and it still had heaps of swarf in it and the threads in the casting hadnt been cut very well, either done in a hurry or with a bad tap because the threads had very uneven broken peaks. Still works brilliantly but you get what you pay for
PostPosted: Wed Apr 13, 2005 7:25 pm
Yeah machining is just so-so and they don't hand finish them. it's worth running a flap wheel thru the bores to get the burrs off and tidy it up.
Also, the diameter at the top flange is only ~42mm. If you wanna run a 45, be prepared to do a little metal removal to get it out to 45mm+. A carbide burr in a die grinder is best, but it will work in an electric drill. Just takes longer.. :wink:
