It is currently Sat Aug 09, 2025 11:39 pm
Post new topic Reply to topic  [ 360 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 24  Next
PostPosted: Tue Nov 16, 2010 6:45 pm
:D :D Good work Madmorrie
good to see a bit of progess
A fair bit of work on those brakes but it'll be worth it
Well done :D :D
Cheers Hallsey
PostPosted: Wed Nov 17, 2010 9:22 am
Nice work. Will be a huge step to get the brakes sorted.
Very jealous of your workshop by the way!
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Sun Nov 28, 2010 10:20 am
Hey MM,
Nice use of the lathe to do some horizontal milling.
Mate, good work, and any forward progress is good progress.
Tricky
PostPosted: Sun Nov 28, 2010 9:04 pm
Thanks guys.
Yeah Tricky, it took some messing, but a bunch of bits bought off ebay have it sorted. Near as I can tell the lathe is around 100 years old, possibly originally treadle powered, so to be able to buy some cheap chinese tooling and get it to do some light milling is pretty cool. I still need to put a new chuck on it for bigger lathe work cause mine is out of whack, but the collet chuck I bought is working great for small stuff. Next item is a billet alternator mount.
Madmorrie
PostPosted: Mon Nov 29, 2010 6:41 pm
Go for it MM.
Sometimes making the tools and uprating the equipment is as much fun as building the car. Cant wait to see it in the flesh.
Tricky
PostPosted: Thu Jan 06, 2011 12:38 pm
Well, I have tried to be busy over the break. Haven't got it on the rotisserie as I had hoped, but as of now it's half together for a final test fit.
I'm thinking I may put the whole thing together as is and get it running, then I can test it a little, then pull it down for the bodywork.
After months of mucking with trying to mill the alternator mount from a lump of alloy, I finally gave up and made it in steel, in one day. Stick to what you know people, it's faster...
The upshot of it is now my old lathe can mill, and when my alt mount distorted with the welding, I was able to just face it off to sit the alt nice and true.
I got a flaring tool the other day to do the hard lines. Last night I got the clutch line finished and couldn't resist testing it. The first system on the car that I can actually confirm works. Good test of my flaring skills as well. Bleeding the clutch by myself at midnight last night wasn't the easiest but it does work, very heavy but no leaks.
Sorry no pics, forgot the cable.
Did anyone find another slave cylinder to lighten the pedal yet?
Madmorrie
PostPosted: Thu Jan 06, 2011 12:55 pm
:D :D :D
Good to see Progress MM, Let the snowball begin
Cheers Hallsey
PostPosted: Thu Jan 06, 2011 5:19 pm
From memory Josh found that the Australian Starlet's were fitted with a 7/8" slave cylinder which helps.
4efte powered Clubman
supercharged 998 race car
PostPosted: Wed Mar 30, 2011 8:47 am
Finished the spit so I can start on the body work. Thankfully this one is pretty sound (that's why I bought it), but there are still a few little nasty patches, plus a few more areas to mod.
I'm actually looking forward to this bit for some reason. Ask me again in a month or so...
Well, I want to be driving this baby next summer so better get cracking.
PostPosted: Wed Mar 30, 2011 4:13 pm
Good work Madmorrie
That rotisserie sure looks better than my double bed mattress
Next summer sounds the goods :D :D
Chers Hallsey
PostPosted: Wed Mar 30, 2011 7:44 pm
Ha, It's some scrap shed trusses I pulled off hard rubbish, an old antenna mast a mate gave me and some other bits and pieces I had laying around. Seems to work OK though.
PostPosted: Thu Mar 31, 2011 5:15 pm
Ingenuity at it's finest :D :D
Cheers Hallsey
PostPosted: Fri Apr 01, 2011 3:24 pm
Necessity is the mother of invention!!
PostPosted: Wed Apr 20, 2011 3:02 pm
Well, the body work is ongoing, but I'm happy with the progress so far. I've welded up lots of miscellaneous holes and a patch over the shifter hole and I've started on the major rust in the drivers footwell. I am loving the rotisserie, it its so helpful for this stuff.
Anyway, pics will tell the story...
I love how little warping you get with the oxy. It is probably slower than a mig, but more forgiving. I don't have a pic of this ground back but it looks good and I've started on the outer panel which covers this. Then I have to do the engine bay side of this triple skin rust trap...
PostPosted: Wed Apr 20, 2011 4:08 pm
Very nice MM
impressive panel making i must say.
I'm a bit worried about the scalpal if things are'nt going right :shock: :lol:
Good to see the build progressing
Cheers Hallsey
