sociallydisabled wrote:
1. What's the average fuel consumption numbers for these injected minis?
2. Who would supply a half cut for this project
3. Would it be harder than I'm thinking?
4. Is it actually worth it?
1. Fuel consumption is oddly enough not all that much less than a small carby car tuned to be fuel efficient. They can get around 7 l/100km (combined cycle), but tend to average a bit more as lots of mini owners are lead foots.
2. As Simon says: contact Josh at mini-imports. I'd get on it quick though as most stock is from Japan and I've no idea what'll happen from here on with pricing availablity if it'll be effected.
3. The process is relatively straight forward, it depends how much of the front cut you're using and if anything gets changed. Hardest parts are the prep work for the AC system if using the late type, and getting the fuel lines in.
4. 'Worth it' is defined by the individual. I wanted EFI, AC, and a quiet smooth running engine without a conversion so it worked for me. Some though don't care for AC and others ditch the EFI, leaving the question of why they bought a front cut in the first place.
benoz wrote:
The rated hp figure for the 1275 spi engine I have in the garage is almost exactly the same as a stock cooper s.
Cooper S's were 75 hp I think, 1.3 SPI is 63 on a cooper variant and 45 on any auto model.
