It is currently Fri Jun 27, 2025 4:58 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 21, 2011 8:02 pm
simon k wrote:
The Duckmeister wrote:
Shouldn't be much worse than bike rear derailleur main pivot springs, which require nearly a full turn once the ends are located before dropping it all into place & slipping the retaining circlip on.
are you able to use both hands, and your eyes to do that job?
And one ear lobe!
PostPosted: Mon Feb 21, 2011 9:33 pm
If you can get away with only using both hands and a few teeth you're doing well.
PostPosted: Sat Apr 02, 2011 8:24 am
I thought I'd throw in my dyno measurements, though they aren't Cooper s.
my Morris 1100 1100cc motor got 20kw atw on a mainline dyno,
and my Morris 1100S 1275cc motor with an sc12 running 7.5psi got 40kw atw on the same dyno. both stock motors aside from the supercharger on the 1275. I'm currently rebuilding the 1275 so we'll see what happens then.
The fleet:
1949 Fiat Topolino
1965 Morris 1100
1966 Mini Van (project)
19?? Morris 1500 (for sale)
1979 Chrysler Regal
1990 FSM Niki
