It is currently Sun Aug 10, 2025 7:46 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Jan 15, 2011 12:48 pm
NG wrote:
it's out for the moment it's just those sliding windows really keep that heat in.
Yeah, that too! I was going to fit Deluxe doors, but then everyone would think it was a converted Van, not a genuine Traveller.
The deluxe doors are now on Mick's Cooper S. Better place for them I reckon. :wink:
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Jan 15, 2011 12:54 pm
haha had the same thought..
PostPosted: Sat Jan 15, 2011 12:58 pm
Put single piece glass in and a felt strip on the side! :lol:
PostPosted: Sat Jan 15, 2011 1:03 pm
No, what I really want is a Clubby estate with the Rover type doors. I'd have no issue with converting that to a roundnose with panels from a Rover front cut. :D
Brett.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sat Jan 15, 2011 1:05 pm
Careful lol. :D
PostPosted: Sat Jan 15, 2011 1:06 pm
Good luck finding one of them! :D
PostPosted: Sat Jan 15, 2011 2:19 pm
I thought about the condenser mounting a bit more after my last post. I think the best 3 options are;
1 mount off drivers side inner guard, ideally with a hole in the inner guard. Could also not cut a hole and mount the condenser a bit away from the guard and get as much airflow as possible through the condenser using one or two fans pushing the hot air into the engine bay. A bit hard.
2 small condenser in front of the starter motor in the grill opening with a fan from a big bike
3 mount the condenser to the outside of the radiator (furthest from the motor with a electric fan either side of the radiator and condenser. This I think is best the more I think about it as it keeps the system very compact and no cutting to annoy roadworthy inspectors.
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sat Jan 15, 2011 4:11 pm
Number 2 sounds okay but in the real world there isn't enough space there.
Number 3 is impractical: the AC system would just get the hot air from the radiator.
Number 1 works with the fan in the guard, that'd how my car is. There isn't enough room to mount the condenser there without a hole, the airflow just wouldn't happen.
PostPosted: Sat Jan 15, 2011 4:25 pm
Number 2 is how Minis from the mid-80's to mid-90's was done for the Japanese market. It's the type NG has fitted to his Traveller.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sat Jan 15, 2011 4:58 pm
And type 2 blocks air flow to the engine. You will run hotter.
PostPosted: Sat Jan 15, 2011 5:07 pm
Missed option 4
4. Man up and take the air con out altogether.
tim
PostPosted: Sat Jan 15, 2011 5:32 pm
Not true, I have a 1275 SPI motor in mine with air con.
The condenser is at the front and I drive around Sydney with no heat troubles.
Cheers Pete
PostPosted: Sat Jan 15, 2011 9:43 pm
I think I'll do some measuring tomorrow as either option 1 or 2 look the way to go.
Tim, can I ask what the point of your post was? You appear to have no interest in the topic.
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sat Jan 15, 2011 10:07 pm
lindsay no 1 is the way to go.
what aircon set up do you have?
if you have the front mount>? you wont need to cut at all.
i have the front mount but im looking for the side mount one where you need to cut.
PostPosted: Sat Jan 15, 2011 11:13 pm
Not an easy job cutting a good 10 inch hole in the inner guard let me tell you. Because the edges run so close there's a lot of tools that wont fit in there to cut.
I used a total of four on mine: angle grinder, tinsnips, jigsaw and dremel.
