It is currently Fri Aug 22, 2025 9:53 am
 Post subject: Mixture Setting
PostPosted: Mon Jan 10, 2011 6:33 pm
Does the nut on the bottom of the SU carby affect only idle mixture, or does it affect mixture right across the rev range?
PostPosted: Mon Jan 10, 2011 6:35 pm
All of the range. :)
PostPosted: Mon Jan 10, 2011 7:49 pm
Yep, the mixture nut changes the mixture throughout the rev range.
The idle screw changes the amount of mixture allowed through at idle - changing the idle screw won't affect the rest of the range.
PostPosted: Mon Jan 10, 2011 7:57 pm
Correction; The idle screw adjusts the idle speed, not the mixture. Only the mixture nut changes the mixture. :roll:
PostPosted: Mon Jan 10, 2011 8:04 pm
That's why I said the amount of mixture. More air/fuel mixture in at idle = more idle speed.
Sorry for the confusion.
PostPosted: Tue Jan 11, 2011 8:56 am
I'm easily confused. :? :? :? :? :? Sorry, you were right. 8)
Users browsing this forum: No registered users and 252 guests
