It is currently Mon Jun 30, 2025 1:38 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Apr 04, 2005 1:24 pm
Well then my stupid idea is: Is it possible with some playing around with the camshaft and grinding out the exhaust ports, to use the exhaust ports as the inlet ports and use the inlet ports for the exhaust ports ? :shock: :shock: :shock:
I know this sounds extreme but the siamesed inlet ports would seem to me to provide a greater restriction than the exhaust ports particularly when the firing order is taken into account.
ie If the current exhaust ports were used as the inlet ports then there would be no suck, suck, wait wait pattern on the shared inlet port but rather the better suck, wait, suck, wait.
And you also have two cylinders with an inlet port all to themselves!!! :D :D
Agreed you would have to get a new cam made and it may not be possible to grind the exhaust ports and valves to be large enough but... I imagine getting a new camshaft made and some rather different head work is going to be cheaper than an 8 port head :D :D :D
OK so you still have some pretty serious exhaust restriction but that is the lesser of the two evils right :?:
Roads need more corners
Last edited by fuzzy-hair-man on Mon Apr 04, 2005 2:52 pm, edited 1 time in total.
PostPosted: Mon Apr 04, 2005 2:42 pm
Steve O'Malley (aka Brickworx) has an 8 port head (from memory) on his race car
it looks good
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Mon Apr 04, 2005 4:59 pm
There was a trick in the 1950's with Ford 4 cylinder side valve motors that had siamesed inlet ports. The trick was to fit a steel plate up the middle of the port to split it into two and then make a manifold to suit. Presto four inlet ports!
 Post subject: Re: Stupid Question
minstar wrote:
Doc, GTI et al. In 250 words or less explain to me a 7 port head, I can understand 8 port for a four cylinder but how do you have 7 ports for 4 cylinder
Confused Matty.
Read Vizard's writings at the link in my original post.
Chris
Everything I like is either
PostPosted: Mon Apr 04, 2005 5:04 pm
We did the same with Healeys. Not really successful though as the plate and the head sort of had different expansion rates. I think the same idea was used on Holden Red Motors more successfully.
Chris
PostPosted: Mon Apr 04, 2005 7:30 pm
There was another trick used post ww2 with the SV Ford Prefects used for racing, same as Fuzzy suggests. They did indeed use the intakes for exhausts, and vice versa. And it worked. But, they had 4 exhaust ports. I doubt it would be as effective with 3 inlets on an A series.
Anyhow the magic 150HP barrier has been passed now by a 5 port 1300. Greg Malaure is running it. :P
PostPosted: Tue Apr 05, 2005 8:57 pm
Here's a rare beast, Weslake 8 port. Real rocking horse doo-doo.
<edit> Looks like it's running stock Cooper S forged rockers?
8)
Last edited by drmini in aust on Tue Apr 05, 2005 9:37 pm, edited 1 time in total.
PostPosted: Tue Apr 05, 2005 9:33 pm
Hey now that IS nice!!! :shock: :) 8) 8) 8)
PostPosted: Tue Apr 05, 2005 9:44 pm
All set up for port injection, too. :P "Would you like petrol or NOS with that, Sir?"
PostPosted: Tue Apr 05, 2005 9:47 pm
:lol:
Whose is it? I bet it would be exxy :shock: 8)
PostPosted: Tue Apr 05, 2005 10:29 pm
Pretty sure it was mechanical injection, I dunno whose. But you could fit anything current on there. :wink:
PostPosted: Tue Apr 05, 2005 10:37 pm
Well cross flow heads arent REALLY that proven.
Because Justin on here (paddy93) drives the Cooper S out at Mallala in Nb class and he's still got his A series head which puts out about 100 horses, while another person's crossflow (arden maybe?) head puts out the same power; but i dunno what other work Justin has had done to his motor.
PostPosted: Tue Apr 05, 2005 10:52 pm
Main benefit of an 8 port is better torque. You can get big power (over 150 at crank from an Nb motor) from a 5 port but you won't drive it on the street. With an 8 port, you could. :P
PostPosted: Thu Apr 07, 2005 5:31 pm
How possible is it to cast your own one of these things?
Say you allready got access to a milling machine etc.
It it a impossible dream?
Anybody done anything like that before?
Personally I wouldnt mind getting my hands on one for a few hours and make some drawings of it.
Fez
1965 850 Mini Van
1972 Clubman Van
Member of SDMC
PostPosted: Thu Apr 07, 2005 6:57 pm
An Arden 8 port X-Flow, when set up well,,,will out do any 5 port , simple as that,,,why???,,,because the punch you get , right the way through the power curve , is just far far greater than a 5port,,,especially in the mid range,,,wicked pull factor
if you havn`t driven one then don`t say didly about em, especially anything bad about em, cause it`s "ALL GOOD",,,you really have to drive one to understand what i`m saying,,,a 5 port still keeps it`s "Hole" in the rev range, na matter what cam, what head shape, exh system, whatever,,,there`s allways a droop somewhere & funny enough,,, if the 5 port is set up for full house revs like 8-9000rpms. then a well set up Arden to suit 7000rpms will most likely sh!t all over it.
if someone`s Arden isn`t as good as another fellas 5 port, then there`s something wrong with the engine build or the driver is not driving it right.
just my 2 cents worth,,, i`ve had the pleasure of driving them on a number of occassions,,,anyone remember the Swinton bros,,,Phil`s car was an awsome thing, & yeah, Arden 8 port :-) very fast mini indeed.
