It is currently Fri Jun 27, 2025 8:36 pm
 Post subject: Carby Ramstacks?
PostPosted: Sat Apr 02, 2005 10:33 pm
hi all. stupid question i know but, what do carby ramstacks do?
PostPosted: Sat Apr 02, 2005 11:02 pm
do they only run with dellorto's?
 Post subject: Re: Carby Ramstacks?
PostPosted: Sat Apr 02, 2005 11:03 pm
1. Increase flow into the carb by smoothing air entry. More power.
2. Increase induction length, which can improve torque.
3. Improve low speed running due to better mixture control (Webers & Dellortos).
4. Increased `Bling' factor.. :P
Short ones give improvements 1 & 3 above, while still allowing an air filter to be fitted. These are often called `stubstacks'. 8)
PostPosted: Sun Apr 03, 2005 6:57 am
Can be fitted to SU's and Dellortos/Webbers
If you can find them or get dome one to make them :wink:
PostPosted: Sun Apr 03, 2005 7:04 am
You can buy them for SU's- either short or long type. Weber & Dellorto ones (for use without filters) come in various lengths.
Russell Engineering (in Sydney) makes short ones that fit Weber only.
I made a batch of short ones last year that fitted both Weber & Dellorto but I'm out of stock now. Might make more if I get enough orders. :wink:
PostPosted: Sun Apr 03, 2005 7:32 am
I'll take one for the HIF44...similar to the Dellorto one
PostPosted: Sun Apr 03, 2005 8:02 am
You don't need that :P :lol:
PostPosted: Sun Apr 03, 2005 8:08 am
Why Josh its only a HIF44
PostPosted: Sun Apr 03, 2005 9:09 am
That's what you have on Morris yea? you don't need any more power than you have..stop being greedy :lol:
PostPosted: Sun Apr 03, 2005 9:56 am
You never know what maybe around the corner :wink:
PostPosted: Sun Apr 03, 2005 1:33 pm
sweet as, cheers. how do u fit them? substack-filter-carby? :?
PostPosted: Sun Apr 03, 2005 2:41 pm
Yep, me too! I wanna put one on with a sock 8)
PostPosted: Sun Apr 03, 2005 4:48 pm
For HIF and HS carbs, you can buy 'em already. Short or long type are on MiniSpares and MiniMania sites, somewhere.
I saw some at Padstow Pirates- can't remember how much $$ they were.
Siclad, they go on the front of the carb. If you have a deep enough filter they go inside it, otherwise put a UniFilter etc sock over it.
Stubstacks like I made are real short, to provide a radiused entry to the carb- they sit on the backplate of the filter and are held on by the filter screws. These will fit inside a K&N, Ramflo, Pipercross, etc. Only fit Weber/Dellorto, I never made them for SU's....
