It is currently Tue Jun 24, 2025 9:54 pm
 Post subject: honda's...
PostPosted: Tue Sep 21, 2010 8:10 pm
Who knows which model, year and size Honda engines are the best for conversions? And what cars to find them in....?
Cal
'63 850/1100 + more cooper goodies
PostPosted: Tue Sep 21, 2010 10:00 pm
Mainly Honda civics and integras I think. Either twin or single cam Vtec's, 1.6L and 1.8L engines are generally used.
When it comes down to an engine conversion you need to look at;
-BHP and Torque out puts,
-initial cost of the engine and gear box and everything else needed to run the engine,
-SIZE, will it actually fit in a round nose, clubby or extended nosed mini,
-weight of the new drive train,
-engineer costs and the cost of making a new subframe.
Their is a lot of other things but these are some of the main ones to consider. Unless you are in love with the idea of a Honda powered mini start looking at other makes ie Starlet 1.3L, Swift 1.3L, Civics as mentioned, charades etc etc.
PostPosted: Thu Sep 23, 2010 12:58 pm
the engine people refer to as a VTEC is a B16A engine - twin cam 1600 variable valve timing. Ring a Honda wreckers and ask for one
 Post subject: Re: honda's...
PostPosted: Thu Sep 23, 2010 10:29 pm
Cal
have a look at 16 valve mini club
mini regards
peter d
1st victorian road registered vtec mini.
PostPosted: Thu Sep 23, 2010 10:51 pm
FYI - That's http://www.16vminiclub.com/forums/
-Alan
PostPosted: Fri Sep 24, 2010 6:16 pm
thanks guys ill check it out now
