It is currently Thu Jul 17, 2025 9:53 am
Post new topic Reply to topic  [ 119 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
PostPosted: Fri Jun 04, 2004 8:13 pm
Once again after a little help.
Things are progressing well on my supercharge set up :D but some one raised a question.
With the extra power what kind of top end speed will I be looking at from my Metro gearbox. Is it worth investing in having a fifth gear jammed in there?
Is the standard gearing on the Metro (as this is the motor set up I have) that different to the Mini?
PostPosted: Sat Jun 05, 2004 9:35 pm
On most Mini 5 speed boxes I've heard it said that 5th is the one most heavily loaded, and `likely to wear' if turbo or blower or a BIG bore motor is used.
Basically, the bearing setup in any Mini box is not designed for extended use in the indirect (including 5th) gears.
Proper 5 speed boxes (eg Alfa, Fiat, BW T5, Supra etc) that are designed that way all have real ball or parallel roller bearings on the cluster gear, not crappy little needle rollers running on a shaft made from dubious quality steel....
Solution? I'd forget 5 speeds with all that torque U got- just fit a taller diff- 3.1 or 2.7 etc. 8)
PostPosted: Sun Jun 06, 2004 10:58 am
I've heard other comments similar to Doc's regarding the 5speeds that are availible for mini's.
dewey
dwightgunning.com
PostPosted: Mon Jun 07, 2004 1:36 pm
Sounds good, and cheaper which is always nice.
Make it faster...
Make it harder...
But make sure it's a Mini!!!!!!!!!!!!!!!!
PostPosted: Tue Jun 15, 2004 2:41 pm
So, basically, the 5 speeds are only if you have a slightly warm 1275.. hmm. Considering I was thinking of going the 5 speed option. Basically I had allowed about $4k for the engine and $4.5k for the box. Might have to rethink that now. Wonder if I should put the money into an alternative engine..
You're only supposed to blow WHAT off?
PostPosted: Tue Jun 15, 2004 3:29 pm
My thoughts exactly a_m_a_d_a_a_m. Gees that's hard to type.
PostPosted: Wed Jun 16, 2004 1:47 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
2.7 ratio top gear 4500 rpm 160 or 170 cant remember now long long time ago
makka
PostPosted: Wed Jun 16, 2004 2:53 pm
you'd need something pretty beefy to pull a 2.7 wouldn't you? Wonder how it would take off in first. I'd love to test drive a car that had a diff like that. I've considered it or a 2.9 but wonder about how viable it really is. Take off would be a little slower but revving it out a little in between gear changes and it wouldn't be that noticable, would it? I don't know.. brain liquifying here...
yes, I didn't think about typing it all the time when I came up with the name but...
PostPosted: Fri Jun 18, 2004 1:16 pm
If I remeber correctly Jan's mutant mini (the car, not the forum member!) runs a 2.9 or a 2.7 with a torquey 1380cc? It goes very well anyway! 8)
My mate's stock MPi powered Mini has a 2.9. It is a little slow off the mark, but once it gets moving it is not a problem.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Jun 18, 2004 6:34 pm
Where abouts on the diff can you find what ratio it is? Does anyone know what the standard Metro (non turbo) is?
Make it faster...
Make it harder...
PostPosted: Fri Jun 18, 2004 7:23 pm
Which Metro? :)
There were different ratios on different models, ranging from 3.44 on the MG to 2.7 (or 2.75??) on some economy models.
Generally I think they were 3.2 on the 1275 manuals. But the only really accurate way is to remove the cover and start counting teeth. :roll:
Someone else here may know more than me, I've only just started deliving into A+ stuff...
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Fri Jun 18, 2004 7:48 pm
I'm thinking about building a 4 synchro SCCR box because I've already got a gearset- but if I keep the 3.44 diff (10" wheels) with its 2.5:1 1st gear ratio I might get outdragged at the lights. Can't have that.. can we?
So I'm thinking maybe a 3.64 or 3.76, and some new earplugs! :lol:
Oh bugger, the speedo will read even more wrong too..
PostPosted: Thu Oct 26, 2006 6:45 pm
hi i have put a 2.65 diff ratio in my mini. it has a 1100 motor with twin sus, electronic dizzy, 1.5 rollers, high compression ported and polished head and ive had it to 5900rpm in 4th and it scared the crap out of me. if anyone would no how fast this is id like to no i still havnt got the speedo recalabrated. i think it would be close to 200?
i like to drive on rails
PostPosted: Thu Oct 26, 2006 6:50 pm
The only way it could get to 200 is if you slipstream someone.
Download a program called gearcalc http://www.locost7.info/gearcalc.php it makes it very easy to work things out.
PostPosted: Thu Oct 26, 2006 6:54 pm
Probably about 170-180...tops
