It is currently Sun Jun 22, 2025 4:39 am
 Post subject: MG Metro Engine
PostPosted: Tue Jun 15, 2004 1:19 pm
Im still quite curious about these MG Metro engines. They seem like the best option to start with. So ive got a few more questions.
1) Do all mounts fit exactly as the mini engine did?
2) What are the diff and gear ratios like?
3) Is the MG Metro engine as strong as the MG Metro Turbo engine?
4) Does anyone know a way of getting either one of these? (i.e via x company)
5) Are all/most parts interchangable with mini performance bits? (i.e cam)
Any help would be muchly appreciated.
regards,
MiK
 Post subject: Re: MG Metro Engine
PostPosted: Tue Jun 15, 2004 6:01 pm
hey m8 mg metro motor ( im assuming you mean A series metro) will bolt straight in using mini engine mounts, metro motor isnt as strong as metro turbo, diff ratios are for 12/12 in rims so should be fine unless u run 10in rims ( which means cooper S discs :roll: ) thisnt common knowledge but metros were forsale in new zeland so you would be better off to contaca a new zeland mini club and go from there :)
lookin for another clubby
PostPosted: Tue Jun 15, 2004 6:22 pm
well i currently runon 10x6 minilites w/cooper discs..
so whats that mean about the ratios :S are the gearboxes any stronger? would it be just better to get another gearbox, or recondition my own?
Thanks HEAPS for the info tho mate.
I'll look into it semi-immediately :) was great news tho :)
regards,
MiK
PostPosted: Tue Jun 15, 2004 6:33 pm
hi M gearboxes are seen to be more forgiving than aussie ones,diff ratios vary from 2.9 up to 3.7 however 3.44 seems to be the most common ie:cooper s ratio
pm me if you want one as next shipment arrives in 6 weeks time have 5 left also will be getting a few NEW OLD STOCK A+ gearboxes not remanufactured ones will be about $700 mark depending on dollar
REGARDS JOSH
Users browsing this forum: No registered users and 25 guests
